Is it possible to run an ELD in a 97 FLD?
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by radarmonkey, Nov 2, 2018.
  1. radarmonkey
    radarmonkey Bobtail Member
    15
    12
    Dec 13, 2010
    Edmond, Ok
    I want an older truck, the company I'm leased to will not allow cellphone apps etc for ELD use. I don't care about California. Is it possible to have an ELD hardwired into a 97 FLD series 60 Detroit? Thanks.
    KB3MMX Thanks this.
  3. mover man
    mover man Road Train Member
    1,698
    1,801
    Feb 21, 2010
  4. radarmonkey
    15
    12
    Dec 13, 2010
    Edmond, Ok
    That was my hope. Will the current ECM work or will I need to buy a newer/fancier one from Pittsburgh Power or Freightliner?
  5. Ridgeline
    22,482
    118,153
    You can't just buy a new ecm and throw it in.
  6. Number9
    Number9 Bobtail Member
    15
    16
    Oct 29, 2018
    Great White North
    If it has an ECM, chances are you can run an ELD in it. If you're staying south of the border, you're not legally required to. Things are murkier if you plan on heading into Canada. There is some (unconfirmed) talk that the exception may be a little less generous on our side of the border (could be 95-96), once our ELD mandate kicks in.
    Your best bet would be to contact various ELD providers and see if they have a hardware solution for you. You may be stuck with one of the more established players.
    radarmonkey Thanks this.
  7. Banker
    Banker Road Train Member
    4,201
    12,674
    Aug 19, 2012
    I have a 96 Series 60 in a 2015 glider. The company I lease to requires an ELD and it hooked up with no issues. I assume your rig will have the data port which is where mine was hooked up. They put a wyed pigtail behind the dash so the data port is still usable for engine diagnostics.
  8. FLHT
    FLHT Road Train Member
    1,406
    2,479
    Aug 2, 2014
    If its a mechanical motor then the answer would be no.
    I would check to see if this company would even lease on a pre ELD truck, many will not.
  9. radarmonkey
    15
    12
    Dec 13, 2010
    Edmond, Ok
    That's great news, thanks.
    Banker Thanks this.
