Hey the all,
Air brake system is building air but at 120 psi all hell breaks loose. Air still comes out of Air dryer/purge valve and purge tank begins to pop off. I have changed the governor and purge valve. Any thoughts on what it could be?
https://youtube.com/shorts/AjKvYH48Gh4?si=WwkkvTrrPvazdeUX
Is it the compressor?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MemphisOrion, Jul 14, 2025.
Sounds like the pressure relief valve on the compressor is popping off. Maybe an obstruction in the discharge line, or dryer.
Hard to say. It acts normal until thenMemphisOrion, beastr123 and Rideandrepair Thank this. -
MemphisOrion Thanks this. -
I seen some slide valves in the head of Wabco compressors fail and do something like that. After the dryer poops off turn off the engine, unhook the compressor outlet line and start the engine. is it still pumping air? Be sure to check air pressure to the compressor unloader line before just buying a compressor or head.
Thanks!! I'll try it in the morning!
