is it worth it
Discussion in 'Oilfield Trucking Forum' started by ORONA TRUCKING, Apr 10, 2013.
  1. ORONA TRUCKING
    ORONA TRUCKING Bobtail Member
    5
    Feb 20, 2013
    Im looking at a 98 peterbilt / Detroit / 1.4 miles/ 70%tires/ to haul vacuum trailer/ just local hauling $12,000.
  3. Driver of the year
    Driver of the year Medium Load Member
    442
    249
    Sep 28, 2012
    Tampa FL
    That $12,000 could easily turn into a $22,000 deal. That is a tractor with an inframe ready at any moment. I would pass on it.
  4. ORONA TRUCKING
    5
    Feb 20, 2013
    wat should i look for ? anything specific..Driver?
  5. Chibob
    Chibob Medium Load Member
    387
    196
    Jul 23, 2012
    Columbia, Missouri
    Sometimes you just can't tell until you haul a load. Then you can feel if it is pulling on all cylinders. If you have a heat sensor you can hold it next to every cylinder to see if it's firing.
    If possible test drive it while pulling a loaded trailer. You'll know then if it's running right. If you can listen to the motor and you hear any noise like a lifter or a main bearing then pass on it.
  6. Ridgeline
    22,365
    115,986
    Start with a good inspection by someone who knows what they are doing.
    Get a Dyno done to see what the blow by is for that engine.
    But no matter, a used truck when purchased even with key tests may be a lemon.
  7. ORONA TRUCKING
    5
    Feb 20, 2013
    TKS !! i will be asking the mechanic i use to give it a good inspection before handing over the $$$ !!!
  8. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    no more than 8k
  9. bigcountrytex
    bigcountrytex Bobtail Member
    7
    Ha more like no more than 6k
  10. oronatrucking
    oronatrucking Bobtail Member
    10
    Jul 18, 2013
    odessa,Tx
    Is it true tat we have a new law with the logs in texas about going to the off duty for .5 after 6 to 8 hrs and then back to driving or on duty !! Tats wat our company told us at our last metting ! if anybody got any info on this please repond
