Is my turbo failing?
Discussion in 'International Forum' started by irishluck09, Sep 9, 2021.
  1. irishluck09
    irishluck09 Light Load Member
    271
    140
    Nov 24, 2019
    17 lonestar with isx15
    My mechanic discovered oil coming out of my turbo before my air 2 air boot.
    I've been told by 3 shops that it's bad or that it's going bad because of this.
    Had it taken to international and they it's not bad. That they found a small leak in the charge air cooler and the air 2 air boot. Which there saying the pressure loss would cause oil to come up through.
    Reguardless I've always been told that a turbo spitting oil isn't good and will fail. Is international trying to pull one over on me?
  3. ChuckMartel
    ChuckMartel Light Load Member
    160
    94
    Jan 22, 2021
    If your turbo impellers aren’t contacting the housing and there is next to no end play your turbo should be fine.
    Dino soar and God prefers Diesels Thank this.
  4. God prefers Diesels
    4,198
    22,264
    Jun 26, 2020
    South Texas
    Thrust play too. Should have slight end play, and next to no thrust play.
  5. irishluck09
    271
    140
    Nov 24, 2019
    But you guys are saying a little oil is okay?
    My truck is at an international oil where they have "thoroughly" gone through the truck and turbo and say the turbo is fine. Just that there was a boost leak on the charge air cooler.
  6. Magoo1968
    Magoo1968 Road Train Member
    2,050
    5,466
    Mar 18, 2021
    St Malo mb
    If you idle truck at low rpm some will have fuel slobber which looks like oil if clamps are leaking . If turbo is still on warranty sometimes they are hesitant to change it .
  7. pushbroom
    pushbroom Road Train Member
    1,781
    7,325
    Sep 1, 2012
    Turbos used to have actual seals and would not leak at all.
    Now the holset has switched to a seal similar to a piston ring where it needs pressure to seal. Without pressure it will puke oil.
    If you were to disconnect the boost hose it would puke oil out as it has no pressure on the sealing rings.
    A hole in the charge air cooler causes the same thing. International is correct.
    Ross_Tech, Heavyd, irishluck09 and 4 others Thank this.
  8. irishluck09
    271
    140
    Nov 24, 2019
    Interesting. I did not know that. Thats good to know
    Magoo1968 Thanks this.
  9. Inderjit
    Inderjit Heavy Load Member
    745
    725
    Sep 17, 2017
    Might not hurt to replace the crankcase vent filter.
    Ross_Tech Thanks this.
  10. Ross_Tech
    Ross_Tech Light Load Member
    133
    134
    Aug 31, 2021
    Along with boost leaks, and restricted crankcase vents as mentioned above, a restricted exhaust can also cause the pressure differential to make a turbo push oil. Take a look at this chart.
    QUALITYTRUCK and nikmirbre Thank this.
