Is tanker driving physically demanding?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Nuttinlikeanap, Apr 26, 2014.
  1. Nuttinlikeanap
    Nuttinlikeanap Light Load Member
    202
    18
    Jun 29, 2007
    HI
    Im starting to have knee problems and I was wondering how stressful is tanker driving? Is tanker driving a lot of drop and hook? If not, just how many times a day would a driver have to climb up top? Also, Do most of these tanker companys use trucks with manual or automatic transmissions?
    thanks
    Nappin
    mje Thanks this.
  3. kw550cat
    kw550cat Medium Load Member
    663
    596
    May 22, 2012
    brooklyn, new york
    There is not much drop and hook. Climbing on to depends on otr or local. Local can be three or four times a day, otr can be three to four times a week. The transmission depends on the company. It is hard to say but I would say manual. It gets stressful especially if you haul explosive liquid and have tight deadlines due to traffic. Also if you are in the northeast like me where traffic gets rough and o/o or company. I did o/o and you have to think about running a business, the load, and the other things.
    mje Thanks this.
  4. 25(2)+2
    18,749
    45,465
    Sep 18, 2006
    the road less travelled
    We have a guy who used to do food grade, he came back because box was easier for him, and he doesn't have to hook up hoses anymore.
    I'm not sure if it wold be that hard or not, I think he had other reasons for coming back, 4 days out usually, and knowing when and where you are going, he won't do multiple drops like I do.
    mje Thanks this.
  5. realsupatrucka
    realsupatrucka Road Train Member
    2,072
    513
    Sep 25, 2013
    houston tx
    General chemical. ....oil field....food grade....fuel....? All of them are different. ...which one are you inquiring about
    mje Thanks this.
  6. Chinatown
    Chinatown Road Train Member
    74,090
    167,566
    Aug 28, 2011
    Henderson, NV & Orient
    Check the Foodliner website.
    sprinter and mje Thank this.
  7. Nuttinlikeanap
    202
    18
    Jun 29, 2007
    Actually, I was thinking about going down to west texas. Water hauling or maybe Oil etc ?? Generally speaking though, which gig or gigs are the less demanding?
    mje Thanks this.
  8. realsupatrucka
    2,072
    513
    Sep 25, 2013
    houston tx
    Local water hauling or crude oil...tthey have sand our there too
    mje Thanks this.
  9. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    In my experience, water hauling involves a fair bit of stair climbing & walking on/over obstacles. It isn't aerobically demanding, but depending on your limitations it may be too much.
    Typical day: drive to well, climb over waist-high wall or earthen berm, hook up hoses, climb ~2 flights of stairs to top of tank to get preliminary gauge, climb down stairs & step over thigh-high pipes to open valves, wait 20 minutes, climb back over thigh high pipes, close valves, climb up stairs, gauge tank, climb down stairs, disconnect hose, drive to disposal site, wait 45min to get a stall, hook up hoses, wait 30min to drain tank, & repeat the whole process
  10. realsupatrucka
    2,072
    513
    Sep 25, 2013
    houston tx
    General chemical is very easy...only time you get on the tank is to vent it...or make sure your wash out caps are tight...or if your air line needs to go up there....other then that its just dragging hoses...but its easy...so easy you have to watch what you eat lol...
    88 Alpha and mje Thank this.
  11. OldHasBeen
    OldHasBeen Road Train Member
    1,269
    924
    Dec 16, 2010
    You got some good answers. I drove a tanker for over 4 years locally. It all depended on the runs, how short or long they might be.
    In the evening time they would perload our truck. Usally at least one time a day I woudl have to climb on top to open the hatches to load. Them after loading pull up to a place were tehre was air hoses, close the hatcks, & blow the podwer cement off the top of the tanker. Every once in a while if I got short runs I woudl do this 2 to 3 times.
    That part did not bother me the least bit. What bothered me about that job we had several cut throats. Even if they saw you broke down they would not stop & help, they would just use that opportunity to get ahead of you & get another load. I guess we had about 10 or more drivers that was like that. And that was the reason I left it behind me. The pay was pretty good for driving loacl, but I could not stand the cutthroats any longer.
    mje and realsupatrucka Thank this.
