Is the auto engine shutoff a company feature?
Discussion in 'Ask An Owner Operator' started by OOwannaBE, Mar 17, 2015.
  1. OOwannaBE
    OOwannaBE Medium Load Member
    575
    372
    Mar 12, 2015
    Nashville, TN
    When you buy your own truck does it have the auto engine shutoff idle feature after a few minutes? Or is that a company feature just like the speed limit govern? If the truck does do this, can I change it to 10 minute cutoff? There are so many times when I am using my microwave and I engage the cruise control to leave the truck running but it cuts off anyway. At first I thought it was just me but I am starting to think its a bug with the truck since I am sure I press the button.
  3. glockwise
    glockwise Light Load Member
    253
    225
    Apr 24, 2014
    Generally it is a setting in the ecu. Newer trucks emissions filters and such, suffer from idling.
    If you own the truck you can set it to what ever you want. Along with a ton of other items like high idle, high idle shut down over ride (why your truck still shuts down), max cruise speed, max speed, etc.
    Of course you need to have hardware and software to access the ecm.
    OOwannaBE and skootertrashr6 Thank this.
  4. skootertrashr6
    skootertrashr6 Medium Load Member
    639
    6,942
    Jan 4, 2012
    Pueblo, Co
    It is built into the ECM of the truck, if you own the truck you can take it to dealership and get the idle restriction changed to a different time or turned off completely. Also might need to have the high idle adjusted in the computer so that you can raise the rpm's and then set the cruise at that rpm. If company truck then that is something have to discuss with your company.
    OOwannaBE Thanks this.
  5. Powder Joints
    7,687
    7,785
    Sep 25, 2007
    Rosamond, SoCal
    Its a company decision same as speed limiter. Shut them both off in the ecm.
  6. kw600
    kw600 Road Train Member
    1,172
    359
    Dec 9, 2011
    everywhere,usa
    You can turn it all off. Dealership should be able to do it fairly quickly.
    Hey powder joints what's you signature a picture of? Curious if it goes with the caption.
  7. Cat sdp
    Cat sdp . .
    20,997
    73,342
    Apr 8, 2012
    Orion's Belt
    Looks like cement silos with the fill pipes going up the sides.....
  8. kemosabi49
    10,677
    45,837
    Jan 13, 2013
    SW Arkansas
    As said above, a shop can connect with your ecm and change the idle shutoff parameters and/or stop it from engaging entirely. Until you can do that you can try this. It might work for you. On the few trucks I've had with an idle shutoff, after a pre-set amout of time, Usually @ 4 minutes, One of the dash lights (Check engine??) will start flashing It will flash for 30 seconds to one minute. When it's flashing if I tap the either the brake pedal or maybe the clutch pedal, It will discontinue the idle shutdown, the light will stop flashing and the engine will stay running.
  9. OOwannaBE
    575
    372
    Mar 12, 2015
    Nashville, TN
    Yeah I think I did that once accidentally since my truck didnt shutdown and I was trying to figure out what I did to cause that.
  10. DocHoof
    DocHoof Light Load Member
    160
    81
    Sep 2, 2014
    Just an FYI...if you own the truck, make #### sure if you go to a dealership to flash the ECU, tell them to reset the password to something like the last 4 of the VIN or something. They have no way of knowing nor finding out what the password is, so they have a back door into the ECU without a password. If you ever have a major breakdown in BFE, the local shop needing to access the ECU probably does not have the backdoor and can't access the ECU without a password. Just makes it easier for future if you know what the password is.
    OOwannaBE and randomname Thank this.
