Hello , is that elbow fitting on the ECU cooling plate a check valve ? .
Is there any check valve in the ECM cooling system from the fuel fillter exit through the cooling plate to the gear pump entry ?
Ty.
Is the elbow fitting on the Cummins ISX ECM cooling plate a check valve ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Narcis.M, May 6, 2013.
Some cooling plates have a fuel check valve. Not all though. It is the fuel line at the top left as you look at the ECM.
Narcis.M Thanks this. -
All Isx ecu cooling plates I've seen have the entry/exit on the right side (on the side of the plate ), one straight exit in the middle and one elbow entry on the bottom .
I apologize I was seeing cummins but not ISX. Thinking of N-14.
