Can anyone tell me if I train on a 9 speed will I have trouble driving a 10 speed at Swift. The school has 9s to train on. thanks
Is there a big difference driving a 9 or 10 speed?
Discussion in 'Questions From New Drivers' started by phoenixman1928, Jun 15, 2007.
I trained on a 9 overdrive and am now driving a straight 10. Biggest difference was getting used to the gears' different RPM power ranges. Other than that, its just another gear.
I am driving a 10 speed regularly, but used to drive 9 speeds exclusively, it's somewhat easier to go back to a 9 from a ten, but lugging the motor skipping 6th gear soon cures you of missing 6th..
A 9 speed is the same as a 13 speed without the splitter, same pattern of shifting, I prefer a 9 over a 10, but if I had to drive a 10 and had a choice, it would be a Super 10. It's faster to shift than a straight 10. I don't have a choice, the company has 7 10 speeds,none of them Super 10s, and is about 80% 13 and 18 speeds. It's much easier to drive a 13 in hilly terrain with heavy loads than it is to drive a 10 speed. -
I drove Volvos elsewhere, they were old ones, some had White GMC on them. One had the original 9 speed replaced with a 10 speed OD, the speedometer was way off. They had troubles from poor placement of switches and controls, the air valves were too close to the light switch and would pop it loose, the newer ones had two light switches installed from the factory to correct this instead of moving the works. It was hard to troubleshoot.
I still cant stand any Volvo.
I wouldnt own one---fact my co. sold it's older used Centurys easier than used Volvos! But if somebody else 'works' on them, I'll drive them---easy to handle/park on a dime! -
But to each his own.
Now, you and I both know that we'd get better mileage, easier shifting and less stress if they'd just leave 'em as 13's, but what do we know, right?I'd rather have a Super 10 than a straight 10, and rather a straight 10 than a castrated 13.
Wait until you drive a 15 spd.
I hear 15 speeds are really fun, but how about a 6x4. Back in the 70's, the hot setup was an air 4x4, I haven't see one of those in close to 30 years, though.
The common belief, and it is a mis-conception, is that a 13 speed will go faster than a 9 or a 10, it doesn't save much money leaving the splitter disconnected on a 13 speed, but it makes insurance companies and owners breathe easier thinking they slowed someone down. It makes no sense to me , it hurts fuel mileage and a splitter allows faster shifting because of less rpm difference between gears, as well as being faster to shift anyway. My present truck is governed out at 75 and it's a 10 speed geared way tall. The 13 speed I drove for awhile was governed out at 70, actually it wasn't going 70, and it would do that in the top 3 gears with the 13 speed. Both of those trucks would go over a hundred without over-speeding the motor.
The fastest truck I ever drove, had a 9 speed with a 460 Cummins with nothing governed out. That truck was wild, it would lock in the cruise at 80 and it had much more, from talking to others that drove it. It was a 93 FLD 120 with a small flattop sleeper. It ran 1825 rpm at 80mph in 9th.
