Is there a forum such as this for medium-duty truck mechanics?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Moose Holland, Feb 16, 2023.
  1. Moose Holland
    Moose Holland Light Load Member
    55
    85
    Jul 27, 2020
    What I have in mind is commercial trucks Class 4-6. But since this is a heavy truck forum I'll ask a few questions there too.
    Are there any shops that service both MEDIUM-duty as well as heavy-duty CMV's? Do any hire mechanics that only service MEDIUM-duty vehicles or do truck/diesel mechanics generally service trucks in both medium and heavy categories?
    I was a 63B10 in the United States Army. Light-wheeled vehicle mechanic. My MOS only dealt with light-to-medium tactical military vehicles. This ranged from pickup trucks to 5-ton trucks under 26,000 pounds GVWR. I'm considering entering the civilian trade as a repairer of commercial trucks. What trade training do I need over military mechanical experience to be job-marketable? Most military vehicle mechanics are "certified parts changers" as I was. I never received any training or experience in removing engines and transmissions. I was never trained to adjust valves on diesel or gasoline truck engines. None of my army vehicle has such amenities as car stereos, power windows, cruise control or air conditioning. Army trucks are highly Spartan tools of warfare.
    I want to specialize in power trains. Knowing how to correctly adjust valves interests me. Engines, transmissions, clutches, torque converters, PTO's, drive shafts, U-joints, live axles, transfers. I don't like tire/brake/suspension/steering work nor do I like complex electrical diagnostics work. I hate routine services like lube/oil/filter. I like to diagnose things and fix broken things. Busting one's back with commercial tires, wheels and drums is peon work. I did a lot of that crap for seven years in Army motor pools.
    Flat Earth Trucker and D.Tibbitt Thank this.
  3. 201
    201 Road Train Member
    12,278
    25,066
    Apr 16, 2014
    high plains colorado
    First and foremost, thank you for your service. These days, I'd have to think any company would roll out the red carpet for you. There aren't too many credible references like Uncle Sam. 2nd, I'm not aware of a class difference in trucks, mechanics work on everything from pickups to front end loaders. While the rest of the world is going to Hades, a mechanic will have work, and at top pay, for years to come, until the oil runs out, anyway. I'd find a reputable shop in your area, and talk to them. They may even put you though some specialty course, they need mechanics that badly. Mechanics are harder to find than drivers today, and you will be a shoe in. Good luck.
  4. Moose Holland
    55
    85
    Jul 27, 2020
    Thanks for your reply, 201. I did have to remove the steel cab from an Army Hough wheel loader once and that was outside my MOS. As a civilian career, I would want to specialize in the powertrains of road-going trucks. For road-testing, I gather a diesel truck mechanic might need a CDL for Class 7+ equipment. Speaking of the heavy trucks, I prefer Kenworth and Peterbilt.
    I don't know if I would put the following one my resume: I don't do tires, brakes, wheels, steering and suspensions. I don't do "heavy junk" or buses. I don't do trailers. I don't do vehicle electrical and lighting. I don't do trucks above Class 6.
    Many rental trucks and moving vans are in the medium-duty range. So are a lot of trucks in the fleets of utility companies.
    I feel I would need to attend a trade school to specialize in diesel on-road power trains FOR CMV'S. I'm not sure if diesel mechanics tear down/rebuild engines and transmisions in shop or just replace these as whole assembies.
    I don't know what mechanics will have to fix when the oil runs out. Probably wood-burning steam locomotives. Maybe they will someday have all-electric trucks. Corn-oil-fueled vehicles?
    201 Thanks this.
  5. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    Shy away from the I don’t do’s ……
    I am looking for the guys that will scrub the floors if I ask them. But, they never will because I need them for more important tasks.
    One must serve in the trenches and earn his keep to get the training and respect to climb the ladder to the next level.
    Dealer level is the only place where you will receive next level training in the areas you wish to learn and accelerate.
    homeskillet, Oxbow, Bean Jr. and 2 others Thank this.
  6. AModelCat
    158,534
    I don't do's won't get you very far in this profession. As a mechanic, the foreman/service manager expect you to do whatever job they hand you. You may not like what they give you but its either that or be shown the door. Versatility is key.
  7. Moose Holland
    55
    85
    Jul 27, 2020
    One could just say, "I specialize in this and have certification or concentration in that" too avoiding negative terms. One might go to a trade school and get specialized training in engines and transmissions. Ok, one such power train specialist might have to do a brake job or a LOF once in a while. Ok. I have a dim view of this jack-of-all-trades approach.
    Some mechanics may specialize in Kenworths but don't know squat about Volvos.
    Vehicles are just too sophisticated these days for each and every mechanic/tech to know each and every one of those trucks from in-dash radio transistors to torque converters. One would not hire a dentist to perform brain surgery in the medical profession, would they? New vehicles are about as tricky in design as a human body.
  8. AModelCat
    158,534
    At a dealer, they will expect you to work on anything. There were days I would finish up changing a DPF in a skid steer and then be assigned rebuilding a grader tandem or removing a transmission on a dozer. You can't just tell the boss you won't do it or that its not your specialty, it won't get you very far. Manuals, troubleshooting and repair procedures are all on the dealer portals these days. Its not like you're being thrown into it blind.
    A good manager gets to know the employee's strengths and weaknesses and will try to assign work based on that but its not always possible. A good mechanic is someone who is versatile and can adapt to different work.
  9. Moose Holland
    55
    85
    Jul 27, 2020
    Yes, sir, on top of that all, I still believe in good old-fashioned training. Does a diesel mechanic have to work strictly for a dealer? What about wrenching for a company that owns and operates a fleet of vehicles? In the Army, I serviced only a fleet of vehicles the federal
    government owned and the military operated. Technologically speaking, as a truck mechanic for the Army, I did not have to know much more than a half dozen different truck models or series. Gasoline vehicles were pretty much phased out including jeeps and Dodge pickup trucks after my first year of service. We had GM-diesel-V8 powered Hummers, 800 series 5-ton, 900 series 5-ton, deuce and half, light-duty GM diesel trucks and that is about it for my MOS. A few trailers and water buffaloes to service also. What is nice about a fleet of trucks is that you have many of the same kind parked online. During troubleshooting procedures, you could swap out a suspected bad part for one that is known to be good from another vehicle if the same kind. Kinda a cheat method. The army trucks had these black boxes on the firewalls called protective control boxes. Swaping these out was a simple diagnosis. The engine won't start if one of these puppies is defective. I was a certified parts changer for army motor pools.
    Fleet owner/operators hiring their own in-house mechanics are likely going to have a bunch of similar vehicles. Possibly a lot of the same models. Motor freight carriers tend to be brand loyal. They might, for instance, have a whole fleet of Kenworth tractors made over the past 20 years. This simplifies things when you have a bunch of the same kinds of vehicles to service. Working on nothing but Kenworths everyday will make a fleet mechanic a Kenworth expert over time.
  10. Inderjit
    Inderjit Heavy Load Member
    723
    708
    Sep 17, 2017
    thedieselgarage.com has a medium duty truck section. I don't go there often but it looks like a good resource.
  11. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Maybe at a Ford Commercial Trucks dealership, you could be more exclusively medium- or heavy duty, or you might work in the medium duty shop of a MD/HD dealership, e.g., Rush Peterbilt in Denver has a separate medium duty shop. Working as a fleet tech, I’ve finished up working on something like an Oshkosh Striker then a push behind snowblower or golf cart immediately afterwards.
    Anyhow, diesel tech is diesel tech.
    homeskillet Thanks this.
