Is there a reason certain makes of trucks aren't seen often in the oilfield?
Discussion in 'Oilfield Trucking Forum' started by leadfoot80, Jul 18, 2013.
  1. leadfoot80
    leadfoot80 Light Load Member
    199
    34
    Feb 17, 2012
    S.E. WY
    For instance, I don't think I've ever seen a Western Star. I mostly see Kenworth W900s, T800s, and a few T600s, and Peterbilt 379s. A few Freightliners.
    Is there any particular reason why Western Star's aren't used a lot in the oilfields? (Or have I just missed seeing them?)
    And on a side note, what make/model of truck seems to hold up the best under the abuse that lease roads put them all through?
    Leadfoot
  3. Dexterr
    Dexterr Medium Load Member
    384
    327
    Jul 25, 2011
    Lafourche parish
    An all Mack truck is whatever you throws at it!! It looks odd but they are one heck of a workhorse!
  4. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    You're in the wrong place. Lots of Western Stars around here, bottles, transports, sand haulers, you name it. Outside of Freightliners, which I have never seen setup in a truly heavy duty manner, you can pretty much bet the farm on NON-AERO Petes, KW's (particularly the T800), Western Stars and appropriately spec'd Macks.
    It's really more about the chassis setup holding up to the lease roads, than the particular brand. For example, double frame, HEAVY axles (min 20K front, 46K rears), geographically appropriate driveline (here in PA 500hp is considered a minimum, as are 13speeds), etc.
  5. leadfoot80
    199
    34
    Feb 17, 2012
    S.E. WY
    I do see a few Macks, but they're mostly day cabs. A buddy of mine drives one of them, and swears by it, but my company won't even look twice at them.
  6. leadfoot80
    199
    34
    Feb 17, 2012
    S.E. WY
    I pull pneumatic tanks and flatbeds, currently with a Freightliner Columbia. The one thing I have noticed, is that it appears the Freightliners tend to live up to their nickname -- Freightshakers. Does the body style and how it's made make any difference? For instance, it appears the Freightliners are all plastic/fiberglass, so does that make a difference in how much it seems to be rattling itself apart? And how much better are Western Stars, KWs, and Petes as far as construction?
    I do wish the company I work for had the same mindset as far as chassis setup, but right now it appears they're going to quantity, not quality. (Several of the trucks appear to have come straight off the road from Prime, JB, or some such carrier, like my Columbia with Detroit 60 series and a 10 sod Eaton Fuller.) I would kill for a 13spd here in the Rockies.
  7. JPenn
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    Freightliners are lightweight, and just don't seem to be put together well enough to handle the pounding. We've got a few Pete tractors with 450-500K miles and the dashes/doors are rattle free, mirrors don't flap, cabs are quiet, and this is after a service life hauling water and flatbeds in gasfield work. Our Western Stars are much newer (oldest is 2010 I think), a mix of triaxle tankers and 3 or 4 axle winch trucks pulling frac tanks or rollertail trailers, but the same feeling of durability is there.
    A road spec tractor doesn't do well here especially in a sand can. 10 speeds just have too large of a gap between gears to cope with some of our steep leases and access roads, and anything below 500hp is an exercise machine by way of gear shifting. The vast majority out here have 18 speeds. I can't understand how you can cope with a 10spd in the Rockies...here in the Appalachian region we have much shorter grades but they're STEEP (one nearby on a hardtop road is posted at 21%). Being able to split gears makes the difference between making reasonable time up the hill or having to chuck it in the low side near the bottom and crawl up, listening to offers to push/pull you up from all the guys with bigger motors :)
    leadfoot80 Thanks this.
  8. Mayne_Event
    Mayne_Event Bobtail Member
    16
    9
    Apr 23, 2012
    SHREVEPORT, LA
    The company I work for has nothing but western stars
  9. Chipster63
    Chipster63 Bobtail Member
    13
    6
    Jul 12, 2013
    Portland, Tx
    My company has a mixture of 379 Pete's, T800 KW's and Mack's. Lately all they have been buying is 13 speed Mack's - word is Mack cut them a deal so that's all we'll be getting for a while.
    I drive a KW - 10 speed with a kitty. Good running and pulling truck.
  10. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    lots of western stars pretty common acualy probably not quite as much as a pete or a kw but still very common. iv seen guys running all kinds of trucks out there freigtliners volvos macks petes kw's westernstars even seen a old autocar once.
  11. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    And there is price point too. Mack, WS , Pete and KW are expensive per se. Mack is very proprietary too meaning you have to go back to the dealer. There is also a lot that goes into the buy decision like available power.......there was a time you couldn't get a Detroit in a Pacar product .........
    JMO
