Is there a truck FREEZER?
Discussion in 'Experienced Truckers' Advice' started by IROCUBabe, Aug 26, 2008.
  1. IROCUBabe
    IROCUBabe Road Train Member
    2,563
    1,024
    Apr 9, 2008
    Dallas, TX
    We run dry van, not reefer just in case anyone wants to give that option :p My question is basically this, I have a crappy coleman plug in the lighter cooler which bearly keeps stuff even cold, and would never work to house meat more then a day, but I am more interested in something along the lines of a freezer, small one, but that would plug into a lighter switch and keep things cold enough that I could keep meat frozen. Anything like that out there, or do I have an invention I need to come up with >.>
    I want to pack along a small grill and a few packages of meat (say a weeks worth) so I can stop single handedly funding the truck stop restaurants...
  3. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,907
    12,209
    Sep 17, 2006
    WY
    I've got a regular fridge, costly but will freeze the whole thing if you turn it down low enough.
    Cost is close to $500 and requires more current than a simple lighter plug is wired for.
  4. lostNfound
    lostNfound Road Train Member
    3,506
    2,269
    Jun 28, 2007
    Home of the Stampede
    That must be a 12 volt fridge, right?
    Which is why I went the "inverter and $80 fridge from Walmart" route (which, of course, has a freezer section in it).
    (My Scottish and Jewish ancestors would be proud :biggrin_25523:)
  5. Eric the Red
    Eric the Red Light Load Member
    56
    10
    Jun 12, 2008
    Arizona
    While I've never used one (I'm trying to find trucker reviews of them), Engel makes a 12 volt refrigerator/freezer. They seem to start at around $400 and will only work as either a fridge or a freezer, not both.
    RBPC Thanks this.
  6. Plane Driver
    Plane Driver Bobtail Member
    26
    Nov 18, 2007
    i,ve got an engel 45qt and love it. have let it run 5 days without starting the truck and did not seem to effect starting the truck at all. i keep it set on the cooldest setting and it keeps everything frozen. very expensive but worth it for me. it is also very quite, i can bearly hear it at all when its running.
    Eric the Red and RBPC Thank this.
  7. Brickman
    12,907
    12,209
    Sep 17, 2006
    WY
    12v yes, RV style.
    I have an inverter big enough to run a fridge and every thing else. Reason I went with the expensive one is that there was an OEM spot just right in my truck for it to fit. Had I gone with the small 110v fridge it would have taken a lot more room in my truck.
  8. brinkj23
    brinkj23 "Asphalt Cowboy"
    1,165
    322
    Dec 26, 2005
    Minnesota
    I use a small black and decker cooler and it freezes stuff in the front of it, and its only 35 bucks, a little small but if you got two of em you'd be set.
  9. Brickman
    12,907
    12,209
    Sep 17, 2006
    WY
    WOW, I've tried probably 4 different brands and none of them worked for freezing. Barely cool, this was all cig lighter plug in types. After I got the real thing I never had any problems. I went from spending an easy $100 if not more a week to eat TS junk food to that same $100 lasting me 2 weeks if not a wee bit longer.
    2.5 months my expensive one was paid for.
    RBPC Thanks this.
  10. abjz71
    abjz71 Light Load Member
    152
    56
    May 29, 2008
    whichita ks
    i have an inverter in my truck powers computer microwave ect. and i went to Best Buy and bought a small office/dorm refrigerator has a small freezer in it i could have gotten on with a true freezer but wanted fridge space more and i also spent the extra for the extended in store warranty
  11. buck and a half
    buck and a half Mr. Miles & Miles with Many Smiles
    775
    57
    Aug 11, 2006
    madison,me
    I just have a cgrt lighter plug cooler also.If I had a freezer I would definitly stock those freezer pops that walmart sells for two big bags for 5.00.When I am home,I have two at a time to cool off on a hot day.They are habit forming.or sure.
