is there any point in turning up a 3406B..........
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rank, Nov 21, 2014.
  1. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    I read quite a few posts about turning up the pumps on mechanical engines...usually 3406B's. I usually back out of mine when the pyro gets near 1000. I back out on almost every hill I pull in VT, NH, CT, PA etc
    What would be the point in adding more fuel in that case?
  3. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Depends on if your pyrometer probe is pre or post turbo. Wouldn't run it much hotter if it were pre.
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    First off, if your engine is stock and your getting up to 1000 on the pyro you got something wrong.
    Id start by pressurizing the system and check for boost leaks.
    After you you get a clean bill of health on your engine, then maybe think about turning it up.
    They run great opened up and a turbo off a 550 e model./c-15.
  5. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I think u got that backwards. If it was pre at 1000 that's nothin. Now post , it's getting up there for a B cat. Any truck I've ever seen always has the probe post turbo. At least from the factory.
  6. wore out
    wore out Numbered Classic
    15,707
    189,803
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I agree a stock B has prob got a leak on the pressure side or timing issues if it is hitting a 1000. They always seem to pull better if you back up on the throttle and give them a little air when they just start to pull down a little
  7. rank
    9,916
    113,498
    Feb 11, 2010
    Yes it's post turbo. 1000 is nothing...heck it would twist to 1200+ no trouble if I let it.
    I tested for leaks last summer. Nothing major. No leaks from the CAC. It did have a small leak caused from a dent in the round ducting right under one of the hose clamps/boots where it enters the front of the turbo. I banged it out as best I could and then added some JB Weld to fill the rest of the ding. That stopped most of the leak. It makes ~27-28 psi if I recall correctly (it's parked for the winter).
  8. rank
    9,916
    113,498
    Feb 11, 2010
    Yeah that's what I do on almost every hill to keep the pryo between 900-1000. I drop a gear and let and her breathe ~1500 rpm. I haven't floored the pedal yet. You can feel that there is more power there but the pyro stops me from using it. I have no idea if this engine is stock or not.
    Maybe someone has played with the timing?
  9. wore out
    15,707
    189,803
    Jun 5, 2013
    Not knowing if it's stock, if it seems to do fine I would leave it be. I keep the fuel turned to both mine. Course the standard hood truck is anything but stock. It rarely gets past 950. The exhd 359 is just turned up a little with a Borg Warner turbo and matched nozzles it will hit a 1000 if you stay in it. All that being said you are pulling mountains in that area. I'm pulling hills in this area. With me never having run that area it's hard to give a fair comparison
    BeenJammin and rank Thank this.
  10. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    In my old trucks with mechanical engines 1500 was the lowest I would a long grade with. I was usually closer to 1700 or so. Like wore out said it seemed to be happiest in a gear where you could get out of the throttle and still accelerate if you needed to. Some people call this " running free" I did find that it seemed you could lug it and have high pyro temp or rev it and have higher water and oil temps. I chose the latter.
    rank Thanks this.
  11. rank
    9,916
    113,498
    Feb 11, 2010
    Yeah that was kind of what I was getting at. What's the point of turning up fuel if the pyro stops it?
