Is there more then one place to replace AC refrigerant, 379 with sleeper
Discussion in 'Peterbilt Forum' started by Mr. Cob, Jun 7, 2022.
  1. Mr. Cob
    Mr. Cob Light Load Member
    Howdy All,
    I have had my Pete, for four years, in that time the AC has slowly started to lose cooling capacity, gradually blew warmer air. No visible leaks, I found a BLUE capped AC fitting used to add refrigerant on the upper left hand side of the outside firewall, I looked but couldn't find another port, I don't know if the cab and the sleeper share the same unit or if the sleeper has a separate fitting that needs to be filled.
    I followed the instructions on the do it yourself kit, started engine, turned the AC on full, fan on high position, and filled until the gauge read 50. Stopped filling, the AC seems to be blowing a bit cooler but it is not cold. Truth is with the engine running I can't hear if the AC compressor is running or not, looking at the tach if I turn the AC off, then on, I can't see any difference in RPM so I honestly don't know if the compressor is working.
    So if anyone has knowledge of another fill port or a way for an IDIOT to check to see if the compressor is running I sure would appreciate your advice. Oh this is on a C15 single turbo Cat if that makes any difference. Thanks.
    Dave
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    You need to look at the center of the ac compressor to see if it's turning then its on if not spinning then its off when you get it nearly full of freon it will start to cut off and on and the fan will start turning turning on and off when its nearly full of freon so you know it's about full of freon.
  4. Coolbreezin
    Coolbreezin Medium Load Member
    403
    422
    Jun 11, 2016
    Florida
    I have a '91 379, 3406b. I was told that there is a completely separate a/c unit under the bed in the sleeper. I can access mine from the passenger side door. I havent bothered to test or use it as Im a local driver. Check the lines in the side box and under the sleeper in the immediate area.
  5. flood
    flood Road Train Member
    4,167
    4,045
    Dec 25, 2010
    your truck has 2 ac units but it's all ONE system..
    1 compressor runs all if it...
    ducnut, Coolbreezin and AModelCat Thank this.
  6. AModelCat
    161,288
    Should be 2 ports. Low pressure and high pressure.
    Never worked on a truck with a sleeper before but have always been told its just one system but with an extra evap core and blower in the sleeper.
  7. NightWind
    NightWind Road Train Member
    2,714
    19,164
    Nov 11, 2006
    Sunny South, AL
    Have you checked the cab and sleeper air filters to see if they are clean? Are you running the A/C on fresh or recirculated air? Is the fresh air door stuck open ( located behind the air breather on the passenger side of most 379 Peterbilts. Yes it makes a difference. The clutch fan should come on when you turn the A/C on as the head pressure rises.
    There are separate units for the cab and the sleeper BUT they are one closed system with only one set of ports for running a vacuum and adding Freon.
    Save time , momney and aggravation and go to a reputable dealer and WATCH them as they work on it so you can learn something.
    Coolbreezin Thanks this.
  8. Mr. Cob
    Howdy NightWind,
    Had a bad condenser core, replaced and everything works as it should.
    Dave
    ducnut and NightWind Thank this.
  9. Luwi67
    Luwi67 Heavy Load Member
    749
    484
    Oct 24, 2012
    Long island
    I've never noticed a filter in the bunk A/C unit, just in the cab. Is there one in the bunk?
    NightWind Thanks this.
  10. flood
    4,167
    4,045
    Dec 25, 2010
    yes
    ducnut Thanks this.
  11. NightWind
    2,714
    19,164
    Nov 11, 2006
    Sunny South, AL
    Yes but most people don't know that.
