Is there much more sitting around flatbed
Discussion in 'Questions From New Drivers' started by Gonzo1300, Jan 8, 2018.
  1. Gonzo1300
    Gonzo1300 Light Load Member
    237
    113
    Sep 30, 2013
    If you guys have seen some of my other post you know my situation. I decided to go to Roehl. Just waiting to get into one of there classes in GA since it's only about an hour and a half from where I stay. I'm wondering is there a lot more waiting around for loads running flatbed vs van. I would rather run flatbed because I've been running hot shot for over 10 years it's kind of the same speed as what I was doing and I don't mind the exercise tarping stuff we needed. When it comes to loads yes they pay a little more but if your waiting around in between loads I may as well do the van division until I get out from under the one-year agreement.
  3. Dick Danger
    Dick Danger Medium Load Member
    545
    766
    Dec 19, 2014
    Seattle
    I don't know your situation, and I'm not going to look. No offense.
    Dry van is where it's at. You never wait ever. Ever. Unless you find yourself stuck one of those destination dead zones.
    Chinatown Thanks this.
  4. Chinatown
    Chinatown Road Train Member
    74,666
    169,669
    Aug 28, 2011
    Henderson, NV & Orient
    Sometimes flatbed, with some companies, is more regional than OTR. Ask about that if it's an issue with you. Might get more long haul with their "National Van Fleet", but you'll have to ask about that to be certain.
    Gonzo1300 Thanks this.
  5. Kyle G.
    Kyle G. Road Train Member
    3,840
    20,148
    Jan 23, 2016
    Eastern Iowa
    When i worked for roehl years ago, i heard a lot of complaints from flatbedders about not enough miles and too much sitting. I don’t know how accurate that is, some people just like to complain if you know what i mean. I always took it with a grain of salt.
    I did have a couple friends who switched from flatbed to curtainside and did much better. The good news is, it’s real easy to switch divisions if you aren’t happy. Good luck with your class!
    Dan.S and Need4Speed Thank this.
  6. Gonzo1300
    237
    113
    Sep 30, 2013
    I do like the idea of curtain side because you pretty much call anything in dimensions for the most part.
  7. brsims
    brsims Road Train Member
    5,296
    6,521
    Aug 8, 2009
    Meadville, PA
    The contract is for 120,000 dispatched miles. My girlfriend just finished hers, took close to a year and a half.
    Cheap freight, low pay, expensive benefits, crap equipment (especially tarps, which you will use a lot!), poor equipment maintenance.
    Roehl ain't the company they used to be. Old man stepped down (or was forced out), Jr. is running the show. Pure beancounter madness.
    bottomdumpin, Dan.S, DrFlush and 3 others Thank this.
  8. 201
    201 Road Train Member
    12,272
    25,056
    Apr 16, 2014
    high plains colorado
    Hmm, things must have really changed if there's no waiting with a dry van. It used to be, in order of waiting, reefer, the most, then van, then flatbed, and the least would be tanker. I pulled a lot of vans, and it was right behind reefer, "we don't have your stuff ready," or, "we don't have room for your stuff", and wait you will. Then flatbed. Generally, people that order stuff on a flatbed, need your freight to continue doing something. Same with shipping, the stuff is waiting for you. Not to say you won't wait with a flatbed. I hauled shingles out of Cleveland, I sat there all morning once. Tanker, the least waiting, aside from loading/unloading. Usually, customers order tanker stuff when they need it, and will shut down if you don't arrive, so again, they are waiting for you. Hope that helps.
    slim shady, austinmike, ethos and 3 others Thank this.
  9. Dick Danger
    545
    766
    Dec 19, 2014
    Seattle
    No clue I haven't pulled a van since the 90's. Spent most of the past 20 years in the oil field.
  10. Crazytrucker77
    Crazytrucker77 Heavy Load Member
    848
    1,047
    Nov 23, 2014
    Grants Pass, OR
    I run curtain side for Sprinter in the West and I have my loads pre-planned at least 24 hours in advance. I'm never waiting and I get home every weekend for a 34 reset.
  11. TaterFox
    TaterFox Medium Load Member
    331
    422
    Dec 19, 2017
    Ashland City, TN
    The most I sat was when I pulled Van, then later when I went flat, the most I sat was when I was in line to pickup or deliver, otherwise it was run run run. Most of the flat sitting was my tarping time. No idea about tanker, but I'll soon know the answer to that.
