1.75/mile ... Birmingham, AL to Richmond, VA (685 miles) .... 45,000 lbs no touch ... could be 30 to 40 loads per year. Looks like a fairly decent lane with not much going the other direction.
Is this a decent rate ??? AL to VA (685 miles)
Discussion in 'Ask An Owner Operator' started by Tuckster, Mar 7, 2011.
does it cover your expenses? At the current price of fuel, I wouldn't touch it.
For me with fuel where it is that rate is to low. Should be north of $2 a mile or $1.75 plus fuel surcharge.
it is too cheap i.m.o. unless you could line up a real good rate load coming back.
I have been running loads on my trucks from the gadsden,AL area to Pittsburgh, PA fairly regularly. I have been doing it for $1760 on 686 miles(through a broker), if that tells you anything. I also consider Pittsburgh and easier place to get loads out of than Richmond, but that is obviously just my opinion.
You stated not much decent coming out--what you gonna do when you get there?--30-40 loads a year? Is this just for your truck--almost one load a week--if you sign a contract to do what do you do rest of time to make$$ and make sure you are where you need to be to move next load?
Just my$.02 -
I wouldn't touch it for under $2 a mile and that is still rock bottom. And if there is nothing to haul back, No Way cause with the 685 mile deadhead you will be running for less than a $1 A MILE and that would just barely cover your fuel cost.
