Is this a normal sound? 2019 x15 cummins
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Procanadianbudeh, Feb 16, 2023.
  1. Procanadianbudeh
    Procanadianbudeh Bobtail Member
    5
    4
    Feb 16, 2023
    Just bought this truck have put about 9k miles on it, when pulling hills it makes this awful noise. Not sure if it's normal. I'm used to running cats and detroit 60. Power seems fine, fuel economy seems fine but it shakes pretty bad and seems to be a shake coming from the engine. It's still under cummins factory warranty, wanna know if I should get this checked out or if these units just run like this. Thanks in advance for any help!!
  3. Procanadianbudeh
    5
    4
    Feb 16, 2023
    It wasn't at 2k rpm either my analog tach is reading a little bit high was probably around 1800 rpm
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Hard to tell if there's an odd sound from the video but I will say this.. like you I came from detroits and cats and only drove a cummins first when I bought my pete in 2016, they do sound like they could blow apart at any minute, you just sort of get used to it. Drive it like you stole it for quite some time when it's new, mine had a noticeable shift when it finally 'broke in', or maybe loosened up is a better term, somewhere around 150,000 km. It has about 815,000 km now and burns very little oil between changes maybe half a gallon.
  5. BRD TRANSPORT
    BRD TRANSPORT Light Load Member
    184
    69
    Jul 6, 2018
    Check your yoke that connects driveline to trans. make sure it's tight might be allittle loose.
  6. Trukkinfool
    Trukkinfool Bobtail Member
    Mine does it too in fact every isx I've ever driven does it. "Characteristic of a cummins" they say.... I can't wrap my head around that.
  7. Animosus
    Animosus Heavy Load Member
    730
    2,892
    Dec 7, 2015
    SE Wyoming
    Yeah all of ours sound like the gear train is about to exit the front of the engine when under load. lol
  8. Diesel Dave
    9,302
    29,928
    Jan 20, 2010
    Hesperia, Ca.
    Yup, sounds normal for a ISX “Cumapart”. I should know, I have one.
  9. kylefitzy
    kylefitzy Road Train Member
    4,727
    19,680
    Aug 12, 2007
    Kansas city,Mo
    Sounds like a bag of hammers, at idle the mirrors shake bad you can’t even see out of them. I’d still trade my last x15 for this new paccar I have now. Put 630k on the x15 and never once added oil between changes and we were doing 40k mile intervals.
  10. little cat 500
    2,055
    1,100
    Jan 17, 2010
    Abbottstown PA
    sound like crap yep its normal
    Diesel Dave Thanks this.
  11. Short Fuse EOD
    2,786
    8,739
    Jul 29, 2015
    Midwest
    Not normal, fix is replace all injectors and dpf. I know of a guy that got it “fixed” and the engine doesn’t make that sound anymore. Emissions is hard on the engine.
    Diesel Dave and little cat 500 Thank this.
