Is that a steam line? It was loose when I to the tank, so I connected it. To the fitting. The don't really have an air line going to the tank with out a valve? So, it has to be steam.... Right?
Is this red line for steam? Is it connected correctly?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by 77fib77, Apr 1, 2017.
No thats an air line, when hooked up top as you did
You can hook up your air supply line below usually near the front fender .ChicagoJohn, 77fib77 and Just passing by Thank this. -
Are you use air to unload? If not just leave the red hose unconnected. If you are it's like slim shady said. But you better close up that dome lid first.
slim shady Thanks this. -
This is usually the other end of that air line on top
You see the other Chicago fitting below that's for steam77fib77 and Just passing by Thank this. -
I know they have to be tight once I'm loaded. -
I personally check the tank to make sure it's dry then I latch all the dog ears, but only hand tight. -
77fib77 and slim shady Thank this.
We have some multi compartment tanks from the 80s But they are well maintainedOrange713 Thanks this. -
I hope your trainer is taking time to go over this stuff with you..its p.much tanking 101
G13Tomcat and ChicagoJohn Thank this.
