is this the right way or wrong way to haul flatbed trailers
Discussion in 'Flatbed Trucking Forum' started by texas rattler, Jan 11, 2012.
  1. texas rattler
    texas rattler Light Load Member
    76
    13
    Aug 7, 2011
    cat spring texas
    im posting this to learn and i respect yalls opinions, today i spotted a flatbedder hauling two other flatbed trailers stacked up. ok ive seen that before but i noticed he held them on with straps? they were spaced about every 10' or so. my thought would be to use chains, what do yall say. thanks
  3. fortycalglock
    fortycalglock Road Train Member
    6,158
    6,592
    Jun 25, 2011
    Tourist Town, FL
    Use what you have. I've seen it both ways. I paid a guy to haul two stacked flats from MN for me a few years ago and all he did was strap them. It was fun backing my truck off the dock onto the bottom one, hooking up to the top one and pulling it off. That's how I started flatbedding, I bought two of them. Glad I liked it!!!
  4. gravelhauler
    gravelhauler Medium Load Member
    630
    414
    Oct 20, 2011
    Lake Charles, La
    I've hauled stacked trailers from Louisiana To Houston. I used straps and wasn't bothered when I passed through the scales.
  5. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    I use chains to prevent the trailers from going forwards or backwards and then straps for the down pressure. I never felt comfortable using straps for everything. But I also have seen some companies who dont carry any chains and use straps for everything.
  6. texas rattler
    76
    13
    Aug 7, 2011
    cat spring texas
    so chains or straps is ok plus some common sense. thanks gentlemen.
  7. Espressolane
    18,197
    113,043
    Have always X chained the front and rear, then straps over the mid section.
    Never had any problems with that.
    Mommas_money_maker and 123456 Thank this.
  8. sly1
    sly1 Light Load Member
    77
    35
    Aug 18, 2010
    Michigan's Upper Peninsula
    I hauled 3 new ones from the factory. BL had "no chains" right on it.
  9. nctraveler
    nctraveler Bobtail Member
    21
    28
    Mar 16, 2009
    Charlotte,NC
    If you are hauling brand new stacks of flatbeds most new mfg's wont allow you to use chains. I know when we hauled any new aluminum trailers it was not allowed by the factory.
    I have hauled stacks all over the country and never used chains. Just common sense and enough straps that obviously are DOT rated and safe. Myself I would strap the middle deck with its own straps and then 6 more straps over the entire stack. They are very top heavy and with having the middle deck strapped on its own helps with stability. But alot of drivers do it without strapping middle deck. Everyone has there own preference.
    Just use alot of common sense in and around curves and corners.
  10. flatbed60
    flatbed60 Bobtail Member
    30
    Oct 24, 2011
    They wont hardly move if you just strap them down good.
    The only problem I have ever had with them is in wind, if you are running pretty good, they will have a tendency to move you over a little , like they are attempting to fly.
    Keep your speed down to about 70 and don't get feisty with them.They draw so much wind they will cause you to have to fuel going downhill most of the time.
