IShift Problems
Discussion in 'Volvo Forum' started by bmzero, Apr 28, 2016.
  1. bmzero
    bmzero Bobtail Member
    12
    4
    Dec 24, 2014
    2008 VNL 730, 685k. I have owned it for about a year.
    Since owning the truck, it has always started out in first gear when in drive. I have seen it pick a higher gear no more than 10 times. It has been to the dealer three times for a fix, even upgraded to a premium shifter at a cost of 1000. Along with starting in first, it also runs up to 2k rpm before shifting most of the time. The other ishift trucks I have driven are much more calm. I also don't get the up and down arrows on the dash when in drive. These things have forced me to drive it in manual most of the time.
    The few times it has picked a higher gear from a dead stop were when the truck was on a down hill slope. This leads me to believe that whatever sensor is supposed to determine the attitude of the truck is not working correctly. I'm assuming this would be in the TCU, but not sure. Local Volvo dealer hasn't been any help with this issue.
  3. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    Im going to think that the engineers got you beat on this one. The truck may indeed know when it is on a down slope and pick a higher gear to roll off in which may not be suitable in mountain situations.
    If you are not happy and cannot get along with the automatic then I guess you need to find a truck in which you can be happy with. Good luck.
  4. bmzero
    12
    4
    Dec 24, 2014
    I think you completely missed the point. My truck is not functioning the way it was designed, based on my experience in several other iShift trucks. It has nothing to do with me not getting along with the automatic.
    KB3MMX and flood Thank this.
  5. bmzero
    12
    4
    Dec 24, 2014
    I just talked to the Volvo mechanic that worked on the truck yesterday. He said that it was definitely starting in 4th when he drove it. It seems to me like there is a malfunctioning sensor that should determine the start gear (based on load and attitude). I'm taking it back to them today.
  6. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    A attitude/incline sensor would make sense.
    If it thinks it's on a steep grade it'll be more aggressive on upshift rpm and will start in first gear.
  7. bmzero
    12
    4
    Dec 24, 2014
    After spending a few hours at the Volvo dealership with the technician, we have decided that the cause of the issue was one of a couple incorrect settings in the Bendix system. After correcting a few parameters, it starts in 4th and shifts at the proper RPM. It's like a whole new truck.
    It is still throwing a DTC for steering angle sensor, but the best we can tell that's an issue in the harness between the sensor and the ECU. Replacing the sensor does not fix the problem. I'll have to pull everything apart and trace it. That DTC is preventing the lateral acceleration sensor from calibrating, which is why we assumed the issue was related to the lateral acceleration sensor. I will work on that at some point in the future, but for now, the truck is performing well.
    QuietStorm and KB3MMX Thank this.
  8. KB3MMX
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
  9. danrichardstrucking
    danrichardstrucking Bobtail Member
    8
    May 2, 2016
    Is your truck upshifting to 12th by 40MPH?
  10. KB3MMX
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    That depends on the rears...
    My XE-13 won't hit 12th until 60+
  11. danrichardstrucking
    8
    May 2, 2016
    I was asking the guy with the trans starting in 4th
