Isx cm 870
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Illini217, Feb 9, 2018.
  1. Illini217
    Illini217 Bobtail Member
    4
    I have an 07 isx 870 cummins . Throwing code 2357 EGR Valve Control Circuit - Mechanical System Not Responding Properly or Out of Adjustment. does this mean I need to replace egr valve ? Any help would be appreciated
  3. WrenchWrenchWrench
    WrenchWrenchWrench Light Load Member
    131
    118
    Jan 3, 2016
    You will have to remove it and clean it out and see if you can free it up. It has an electric motor as well as a position sensor. The code means its not attaining the desired position when it sends a certain amount of voltage to the motor to move it to that position. If you do end up replacing it, it comes as a kit with the gaskets and a new pigtail to splice into the harness. It DOES NOT come with the small blue grommets that seal the coolant lines that connect to the EGR valve. Buy four of those.
    Illini217 and Justrucking2 Thank this.
  4. Heavyd
    Heavyd Road Train Member
    7,808
    6,258
    Feb 4, 2009
    99% of the time, the egr valve has failed. If you replace it, make sure your ECM has the latest calibration as one of the last updates for those engines was to help extend the life of egr valves by working them more to prevent seizing up. This can be checked with Insite.
  5. Goodysnap
    Goodysnap Road Train Member
    3,747
    9,110
    Jul 12, 2017
    Along with the crappy valve design and repeat failure, Pin drag and pull test both connectors and or replace with new pigtails at the valve and or the complete engine harness. Most of the ones I see the connectors have been unplugged so many times I don't know how they even make connection. Plus the heat from the exhaust takes its toll. The whole reason they went to cold side EGR.
    Heavyd Thanks this.
  6. Heavyd
    7,808
    6,258
    Feb 4, 2009
    That is true, but it is amazing how well connectors last and come apart without damage when people apply a little bit of dielectric grease when they have them apart.
    AModelCat Thanks this.
