ISX coolant low when cold
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by NDtanker, Feb 27, 2018.
  1. NDtanker
    NDtanker Bobtail Member
    12
    Dec 14, 2017
    coolant level is low in degas bottle when cold and rises to full when hot what could be causing this 2004 cm870 ISX 400st
  3. Goodysnap
    Goodysnap Road Train Member
    3,748
    9,115
    Jul 12, 2017
    Fluids expand when they warm, this is a normal condition. Coolant level is something that requires constant attention on your truck that should be checked every day just as often as you check your oil level. Often cold leaks will spring up at clamps and sealing joints as rubber parts expand and contract with temperature changes. Have your system pressure tested for leaks, do this both cold and hot for best results and the best chance at finding all the leaks. If equipped with any silicone radiator hoses, water permiation through the hoses is normal and topping the fluid occasionally is a normal practice.
    spsauerland Thanks this.
  4. NDtanker
    12
    Dec 14, 2017
    true but normally in a degas bottle your full cold is higher than full hot as gas expands liquid goes down in a degas bottle the opposite is happening
  5. Goodysnap
    3,748
    9,115
    Jul 12, 2017
    Say what.......? Cold full is low. Fluid expands as it warms. If coolant level is dropping while running up to temp you have a leak or air in the system.
