ISX Engine Power Issue, won't go over 40mph
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by rgvloads, Jan 21, 2021.
  1. rgvloads
    rgvloads Bobtail Member
    I am having power issues with my Peterbilt truck with ISX engine. My original engine went bad and I put in another used engine. Here are the issues with new (used) engine:
    *Truck does not go faster than 40mph loaded. No power
    *I had turbo rebuilt to no avail
    * Changed turbo hoses since they were leaking a little oil
    Do you guys think it may be the used engine I put in?
    Thoughts?
  3. Harpreet1396
    Harpreet1396 Bobtail Member
    8
    9
    Jun 26, 2019
    Fontana,CA
    Could you post a list of active and inactive codes? Pretty hard to diag low power with no info....
  4. baha
    baha Road Train Member
    4,137
    2,834
    Jul 25, 2013
    ga
    Did you get the ecm. off the truck that you got the motor out of, if not you may need to get your ecm. reset to match your new eng.?
  5. AModelCat
    145,381
    Well it could be a dozen different things. Chances are its a programming issue.
    Was it the same year and CPL number? Came out of a similar model truck?
