isx05, egr issues
Discussion in 'International Forum' started by bino, Feb 12, 2013.
  1. bino
    bino Bobtail Member
    hi! New to the forum, the codes from my diagnostics test codes related to the egr are 1228(pid27), 2348(pid27), 2357(sid146), 2359(pid411). Can i bypass the egr on my 05 isx. The lowest i found for an egr valve was 963.00 and that's only for the part. HELP! Also does code 482 or 2215(pid94) means i need a new fuel pump? Thx for any advice!
  3. Heavyd
    Heavyd Road Train Member
    7,752
    6,186
    Feb 4, 2009
    Can't help you with the EGR, but the 482/2215 is only fuel delivery pressure is low. This doesn't necessarily mean you need a fuel pump. Proper diagnostics need to be done to determine what is causing the low pressure. These pumps are actually pretty good and I have only changed a couple of them. If the low pressure codes are not currently active they need to be ignored. Those codes can be induced every time a fuel filter is changed and the fuel system reprimes itself.
  4. pawpaw1
    pawpaw1 Medium Load Member
    396
    145
    Sep 9, 2011
    Dallas,Ga.
    Your question gets kinda involved , but here goes . I don't know about your codes , without looking them up , but the best way to handle the EGR problem , permantly , is to delete it. $$$$ place called PDI . Then , go to a junkyard. Get another exhaust manifold , take the rear section off. TAke your exhaust manifold off, take the Front section off , put the rear section on , bolt it back up.
    no more EGR. But , you Must do the EGR Delete first. Then , never , ever , let Cummins , or any dealer , hook up to your ECM , Without a Clear understanding that they are not to update it, or change anything.
    You will spend a loft , upfront , but it will save you even more , in the long run. Or , if you're sure the EGR is closing completely , when the engine is off and cold, turn the key to on , without starting the engine , walk around to the EGR , and unplug the electrical connection. Turn the key back to off , wait a few seconds , then you're good to go . You will get a permanent check engine warning, but that's the cheap way.
    Remember , that valve must be closed. Only way to be sure , is to remove the clamp ( it will break , you'll need a new one , $32.00 at a dealer) and look at the valve, to be sure it's closed.
