isx15 jake problems
Discussion in 'Trucks [ Eighteen Wheelers ]' started by pstadem, Oct 6, 2014.
  1. pstadem
    pstadem Bobtail Member
    OK, does anyone have any experience with diagnosing problems with cummins jakes? the motor is an isx15 cm871 485hp 1850tq. the issue i am having is the jake doesn't hold back as well as it should. sometimes I'll know it is functioning properly and it'll build 30-35 psi manifold pressure, but most of the time it only makes about 20 psi. i had it to peterbilt any they found one of the jake heads was not coming on, diagnosed the ecm as the problem, but no change. i brought it back to them and they found an air leak on the pressure side of the turbo and some loose wiring. after that it seemed to work well for a day and then back to the same intermittent problems, although more often than not it doesn't work. no fault codes. hope someone can help me, I've only had the truck about 2 weeks and it's killing me. I am done with the dealer and their no answers, although I don't really have any time to be messing with this I need to learn these isx motors for myself.
  3. Bush chook
    Bush chook Light Load Member
    144
    43
    Apr 27, 2009
    Geelong
    wastegate circlip miising , rocker shafts worn or jake harness if all solenoids and orings are good
  4. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    Sounds like it could be the VGT turbo, as you say it works fine some times and then not. The turbo is what works in stage 3 of the dash switch. If it is consistent on stage two of switch and is intermittent on stage 3 then it will confirm that its a turbo issue. Might want to replace the exhaust pressure sensor first as this is where the turbo gets some of its info/feedback from (cheap parts first).
