ISX15 regen question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by kestrel1, Feb 18, 2021.
  1. kestrel1
    kestrel1 Bobtail Member
    35
    10
    Jan 1, 2009
    Sacramento, CA
    I’m in CA so last year finally had to give up my great old truck for newer “emissions friendly” truck. Still not fully tuned up on this new system. So, here’s my question. I’m a local dump truck driver. Sometimes, my truck ups the rpms from 700 to 760. Is this a regen and is it normal? It’s a 2016 KW T880.
  3. Goodysnap
    Goodysnap Road Train Member
    3,746
    9,109
    Jul 12, 2017
    I dont have any reasonable explanation for the RPM increase difference other than if it is preset into your Cruise/PTO settings somehow. Passive regeneration occurs while driving. If the DPF lamp were on and a stationary was initiated with the manual switch, RPM should be in the 1000 to 1100 range until completed which it should return to base idle.
    If you turn the cruise off does the RPM stay at 700?
    pushbroom Thanks this.
  4. kestrel1
    35
    10
    Jan 1, 2009
    Sacramento, CA
    Forced regen gets my rpms up to 900. This just does it every so often. And I hear the turbo whistling too. Sometimes lasts about 20 mins. And it happens only when I’ve been doing local driving, and no freeway. Just bumping around town. When it kicks in it’s a ##### to go though gears as it throws rpm off. I was assuming it was some type of regen
