ISX15 to X15 Swap
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Harpreet1396, Jan 21, 2021.
  1. Harpreet1396
    Harpreet1396 Bobtail Member
    8
    9
    Jun 26, 2019
    Fontana,CA
    Hello everyone,
    I am needing help with a swap we are doing in our shop. We had a 2014 PETE 579 come in with a seized ISX15 engine and the customer decided to swap for a X15. We completed swap and truck starts and runs good with the ECM from the original engine(ISX15). Now the problem we are having is the new engine’s ECM(X15) will not communicate with CCU. The cruise control, eng brake, or the cluster do not work. Now when the original ecm from the ISX15 is put on the X15 everything works good. They are both cm2350 but the ECM templates are not interchangeable. Any idea how we can get the new ECM to work? Thanks in advance to all replies
    KB3MMX Thanks this.
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    When ever I'm going to swap engines such as this. I always check what is involved with the electronics. I did mine with a dec3 to a dec4 12.7. The dec 4 computer wouldn't not work with the CCu so I used dec3 no issues. You have to more than likely get a harness adpater to match up with pins in ecm to CCu. I sure someone will direct as to where you can get it from. All the best
    KB3MMX, istumped and Harpreet1396 Thank this.
  4. Goodysnap
    Goodysnap Road Train Member
    3,718
    9,032
    Jul 12, 2017
    I would get ahold of Cummins. Should be able to put the old calibration file in the new ECM. This would be the easiest resolution I would think. You will need a fleet count. Pray that its compatible with the newer ECM part number.
  5. flood
    flood Road Train Member
    4,161
    4,031
    Dec 25, 2010
    Problem you will also have is that the X15 is a true down spon engine.
    The ISX15 is not
    Harpreet1396 Thanks this.
  6. Goodysnap
    3,718
    9,032
    Jul 12, 2017
    Another problem.........X is in cylinder dosing.
    2350 is not.
    AModelCat, pushbroom and Harpreet1396 Thank this.
  7. Roberts450
    Roberts450 Road Train Member
    2,237
    3,636
    Feb 6, 2016
    Arent the j1939 communication speeds different as well??
  8. Harpreet1396
    8
    9
    Jun 26, 2019
    Fontana,CA
    Thanks for the replies. Im going to find the wiring diagram for the truck the engine came out and see where the problem is. Im not to good with electrical diag so one of my buddies is coming out to help.
    KB3MMX Thanks this.
  9. pushbroom
    pushbroom Road Train Member
    1,779
    7,313
    Sep 1, 2012
    Print out the parameters off the old engine and manually enter them into the new one.
  10. Harpreet1396
    8
    9
    Jun 26, 2019
    Fontana,CA
    Already did that. Still the same. I ran the truck all day and everything works perfect with the ISX ecm. Going to send it for a trip and see what it comes back with.
    KB3MMX Thanks this.
  11. AModelCat
    159,156
    I can see that being a pretty big issue.
    Vampire and Goodysnap Thank this.
