It's a never ending quest, cut cost!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 2Much2, Apr 12, 2011.
  1. 2Much2
    2Much2 Bobtail Member
    21
    Feb 16, 2010
    Steeler Country
    I'm on a never ending to quest to cut my cost. Tires are a big exspense. Im wandering which brand gives you the most bang for the buck. In other words Im looking for the least expesive tire that last the longest. I drive a tri-axle dump and they are hard on tires. If you drive a tractor you might be getting 3-4 time the life that I do.
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Tires life on dump trucks is really short. Especially 3 axe dump operated on terrain,
    A bit better are COE dump trucks with two steer axes and two drive axes of 8x4, 8x6 and 8x8 configuration, like Volvo FM/FMX ore Mercedes Dump truks. I saw Mack trucks with daycab of this configuration in Crimea too.
    Anyway all these trucks are tire killers.
  4. 98989
    98989 Road Train Member
    5,990
    6,740
    Sep 14, 2008
    8x4 trucks should wear tires faster than 6x4
    you always need to spin tires in mud and all other terrain
    our 4axle mercedes wear its tires on 3rd axle ( 315/80r22.5 michelin xdy3 for about 3week on rocky terrain and also lot of steel armature -that is on demolition site and it used to drive only on this ...) tires were not new completely but has about 10-12mm of pattern
    last axle has almost new good year rhd (regional tire) with square pattern and they are still on truck but now are completely cut off because of wheel spinning in rocks but there is still about 7-8mm of tire but they need to be changed soon
    also truck was overloaded always had about 30000lbs per axle
    and after that job it made another job of about 5 months and made another 20000 milles
    now on third axle is continental i think they have good ratio between lifetime and cost
    but michelin had 3750kg per tire ( on double mounting ) other tires has 3350kg
    maybe best thing are retreads for tipper
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    there is Maranginy rethread shop in Lugansk. We use rethread, but not for steer axe
  6. 98989
    5,990
    6,740
    Sep 14, 2008
    really cost effective for steer axle are kormoran (company owned by michelin) not sure are they available in US
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Yeah, I used Kormoran too. But Michelin is better anyway
  8. 98989
    5,990
    6,740
    Sep 14, 2008
    yes i mean that nothing can be compared with michelin
    but also in price too
    for road and today economic problems i would chose continental
    anyway i think only good careful driver can make tire like longer
    no one can get you better tires for less money so try to often check pressure and try to prevent wheel spinning
  9. Rig Wrench
    Rig Wrench Medium Load Member
    398
    66
    Dec 24, 2010
    northeast
    I would recomend looking into som recaps for the drives and lift axles. we run them on all 10 triaxle dumps we have and save a bumdle at the end of the year. often times off road you run the risk of damaging a sidewall or destroying a tire alltogether, makes more sense to run the cheeper recaps. We run General brand H load rated on our tractors and get them recaped for our dumps. Bandag cap I believe. Also helps to keep the drives rotated on a schedule to get max life.
    Sad this has became a buisness of saving, not profiting.
