IVA (code 92) on a 2007 T2000 Kenworth
Discussion in 'Kenworth Forum' started by brumic0307, Nov 15, 2011.
  1. brumic0307
    brumic0307 Bobtail Member
    I have a 2007 T-2000 Kenworth and it is flashing a code 92. I do know that the code 92 is the IVA, but i do not know where it is on the engine to check it? The code only flashes when i am loaded, and very rarley comes on when i am bobtailing. Any info on this would be EXTREMLY appriciated. Thanks!
  3. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    it wont flash when bobtailing. your not loading up the engine enough to activate the iva's. it might be the pressure silenoid or sencer for the oil pressure that controls the iva's. located on spacer for valve covers toward front of engine on passenger side. it also could be one of the silenoids acting up on the iva assemblys under the valve covers.
    brumic0307 Thanks this.
  4. brumic0307
    Thank you so much, i will get this info back to my husband and see if we can get this thing fixed!! Again thank you!!
  5. gonzo01
    gonzo01 Light Load Member
    74
    5
    Jun 14, 2010
    denver, co
    92 is for viva #2. it sits under the first, forward most, valve cover. The viva may need to be replaced or there may be an oil leak associated with it...
