Ive got a road test for employment with Con Way Freight- what will it consist of?
Discussion in 'Questions From New Drivers' started by denton, Aug 23, 2011.
  1. denton
    denton Light Load Member
    Any know exactly?
  3. NewNashGuy
    NewNashGuy Road Train Member
    1,616
    752
    Jul 27, 2011
    US and Canada
    Sorry I wish I could help you. I am only replying because I looked at getting more info about con-way too as there is one here in Nashville.
  4. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    It's going to consist of a pre-trip, short road test, back-up test usually straight back and then they will most likely have you unhook, then hook. Make sure to use your hazards when backing and doing yard exercises and if you want to butter them up toot the horn before backing and get out and look at least once! While on your road test be sure to constantly be looking in both mirrors and look way ahead of what you are doing. Seatbelt is a given! Never coast in neutral and don't shift over railroad crossings! This should at least get you to pass. Good luck!
  5. CenutryClass
    CenutryClass Road Train Member
    1,539
    859
    Feb 15, 2006
    Its just like your CDL road test, maybe less in depth. depending on the driver trainer, you might run through the whole gamut, maybe not.
    When backing, even if you know nothing is there get out and look. GOAL. It is the right thing to do, and you'll win points with the evaluator.
    Just take your time, dont rush and be safe
  6. CenutryClass
    1,539
    859
    Feb 15, 2006
    Use the pointers of the smith system if you can
