For those of you who have used both of these electronic logging systems (E-log,ELD,EOBR), I am curious what pros and cons you would point out for each of them. (I am not referring to the perceived negative many would list about being required to use an electronic log in the first place!) I am considering an option where I would have a choice between the two systems, and I am not familiar with J.J. Keller at all. I have only used the Qualcomm Omnitracs system at this point. Thanks!
(I wasn't sure where to post this thread. Mods, feel free to relocate it if appropriate.)
J.J. Keller vs Qualcomm Omnitracs
Discussion in 'Trucking Industry Regulations' started by farmboy73, Jan 1, 2017.
Page 1 of 4
Paper logs versus Elogs? These forums are filled with either praises or howls.
I consider the Qualcomm a great communiation device back in the day, it has however morphed into a skynet of sorts, that truck is now literally alive to anything that might be wrong. If your key is in the ignition and your body weight is in the seat sensor it knows it and so does Dispatch. I think taken to extremes it will weigh your BMI and measure your blood saturation oxygen before allowing you to drive....
No thanks. I like my old iron. -
JJ keller is bluetooth and tablet based. You can also look at VDO Roadlog no monthly fee unless you want to use web based technology.
farmboy73 Thanks this. -
Personally I like the tablet based device. The one truck I drove with a qualcom I had to put my hat over it to see at night.A21CAV and swaggerjacker Thank this. -
No, just another service provider. Using a tablet based system.
Page 1 of 4
