Jacking Up Axle Required for Lug Nut Retorque?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Jan 28, 2020.
  1. PE_T
    PE_T Road Train Member
    A tire mechanic mentioned this to me, and I just wanted to know what y’all think. I have never seen a tire tech jack up an axle for a retorque.
  3. Luwi67
    Luwi67 Heavy Load Member
    749
    484
    Oct 24, 2012
    Long island
    In my opinion the lug nuts should be loosened and re-torqued. Having the weight of the truck or trailer off of the wheel is smart.
    I've seen people try and re-torque an already "torqued" lug nut by tightening and checking for the click on the torque wrench. I ask "How do you know it isn't over torqued"
    PE_T Thanks this.
  4. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Wouldn't you just be chasing your tail?
  5. Luwi67
    749
    484
    Oct 24, 2012
    Long island
    Lug nuts loosen only 2 ways. 1- not tightened in the first place. 2- over torquing them which over stretches the stud and the assembly looses it's clamping force.
    Heavyd and PE_T Thank this.
  6. pushbroom
    pushbroom Road Train Member
    1,780
    7,319
    Sep 1, 2012
    Re torquing is just to verify they stayed tight.
    If you back the nuts off and torque them, you require another re torque after that.
    So if they lift the axle up in the air what holds the tires from turning? The park brakes? So now you are trying to torque on tires and drum which are fighting against the brake shoes.
    Brakes released, tires chocked and torque them. Nothing fancy.
    ODR, AModelCat, daf105paccar and 7 others Thank this.
  7. Chubby Fly
    Chubby Fly Medium Load Member
    569
    797
    Nov 25, 2019
    #### this is spot on. I was about to post about this but then i reached this comment.
    PE_T and pushbroom Thank this.
  8. PE_T
    So I googled this question and most are saying it’s okay to torque on the ground. Apparently the weight of the vehicle won’t prevent it from torquing lug nuts properly as long as it is tightened a bit while in the air. I wonder if there is a mechanical manual that says something about this.
  9. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    And can also be loosed by corrosion not removed before installation and also dirt caked on the rim before assembly, and hard strikes to the rim that stretch the studs (usually don’t care because rims bent), and the use of anti-seize causing and under torque situation. And the use of anti-seize cause a over torqued/stretched/stripped thread situation. And and and.... yeah just few more than 2 ways.
    Besides that, if they are “over-torqued” to the point the stud is stretched, then you’ll never reach torque when re-torquing. The stud will snap before it ever reaches the proper torque. More than likely your talking about stripped threads, but the same thing applies.
    Re-torquing after a certain miles is to confirm no nuts have backed off because of any of the above conditions basically CYA for the tire shops.
    Re-torque when the wheel is on the ground. If more than one are found loose jack up the wheel remove it, and find out why it loosened before you re-torque and go bee-bopping down the road.
  10. Chubby Fly
    569
    797
    Nov 25, 2019
    over torquing happens when you go to a truck tire place. The ex convicts that work there use 1" impact guns and sit there and hammer on your lugs to about 1000 foot pounds. I have a 1" gun but All you need is a 3/4 and hammer them on. Usually brings them to dead on around 600 foot pound. I usually check a few bolts after i let the truck down with my torque wrnech.
    PE_T Thanks this.
  11. pushbroom
    1,780
    7,319
    Sep 1, 2012
    I think most nuts only call for 500ft/lbs.
    1/2 cordless gets them snug then a bit of turn with the torque wrench before it clicks.
    ODR, spsauerland, SAR and 5 others Thank this.
