Jacob's brake
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brookshire36, Jun 23, 2022.
  1. Brookshire36
    Brookshire36 Bobtail Member
    18
    Apr 28, 2020
    Driving on a unpaved rough road rhis morning, Jacob's brake working fine, made it to pavement drove about 1mile let off pedal and my Jacob's brake wasn't working hasn't worked all day, my motor is a cat c12, and the wires coming from Jacob's brake switch are still running to block, how does it get its power through relay, circuit breaker, I kinda tested the switch on dash and I really don't know if there supposed to light up tester if not working but nothing lit up any help be appreciated thanks
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,010
    2,071
    Dec 15, 2021
    We had an old KW,on rough roads a lot.Once in a while you had to put your toe under the throttle pedal and lift it a little,Jake would come on then.
  4. Brookshire36
    18
    Apr 28, 2020
    I thought about that also and tried it still didn't work, even tried pulling up on clutch pedal
    North Pole Nightmare Thanks this.
  5. Dave1837
    Dave1837 Road Train Member
    1,402
    4,349
    Nov 16, 2019
    Pennsylvania
    Check the clutch switch, just drove a 9200i international with a C13 that did the same thing. There's 2 screws that hold the switch in and one hole is beveled so you can adjust the position of it. Hit a bump and it knocked it off it's position
  6. M22 rockcrusher
    M22 rockcrusher Road Train Member
    1,344
    4,147
    Nov 21, 2020
  7. lester
    2,956
    8,076
    Jan 2, 2012
    NW, Iowa
    Is your cruise control working?
  8. Brookshire36
    18
    Apr 28, 2020
    Nope, the one other thing is that it supposed to have a on and off switch, and another switch for low med and high, they removed the on and off switch awhile back so somehow they got power just going to the low med high switch and somehow bypassed med and jsut have low and high
  9. blairandgretchen
    13,876
    76,138
    Dec 9, 2011
    South west Missouri
    Jacobs Vehicle System
    Bean Jr. and Milr72 Thank this.
  10. Brookshire36
    18
    Apr 28, 2020
    The one thing is I have no on and off switch somehow bypassed it and all I have is off low and high on the one switch , traced those 3 wires and there all going into the block, so was thinking it has to have a power wire somewhere
  11. Milr72
    Milr72 Medium Load Member
    578
    1,419
    Dec 16, 2011
    S W Missouri
    Oh come on! It's a Jake Brake! :)
    Bean Jr. and blairandgretchen Thank this.
