Jake-Brake/Engine fan engaging
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bulldozerbert, Apr 24, 2009.
  1. Reaper'sTrucking
    Reaper'sTrucking Light Load Member
    79
    73
    Jun 1, 2020
    Even Cummins website mentions that the engine fan can rob you of a minimum of 50hp for smaller engines and upwards of 225hp for their larger industrial engines the fan spins while the engine is on but doesn't fully engage till the clutch kicks on, there's a reason why you're able to program the fan to come on with the Jake brake and there's a reason why the rpms will drop twice as fast with the engine fan on manual, and if there's no resistance on the engine when the fan kicks on them you probably have a bad fan clutch and just never noticed
  3. Reaper'sTrucking
    79
    73
    Jun 1, 2020
    So you think once a post is made no one will ever come across it again in the future? Lmao
  4. Reaper'sTrucking
    79
    73
    Jun 1, 2020
    Have never had an engine overheat while engine braking, if you're having that problem I'd suggest replacing the O rings on your cylinder liners cause you probably got a coolant leak lmao, even going down smasher hill with 100k plus have never had the temps reach over 180
  5. Hammer166
    7,617
    27,873
    Aug 18, 2007
    ~8600+' and loving it!
    I didn't say overheat. A jake turns an engine into a giant air compressor, and last time I looked, any air compressor with a 500hp input had a cooling system on the compressor.
    I would suggest that if the jake isn't warming up the engine in low speed / high load conditions, that your thermostats aren't properly closing. Because that engine is still doing work.
  6. ducnut
    ducnut Road Train Member
    2,683
    8,131
    Dec 31, 2010
    SPI
    Apparently, the humor was lost on you.
    Vampire and Hammer166 Thank this.
  7. Vampire
    Vampire Heavy Load Member
    778
    27,972
    May 14, 2011
    Transylvania
    He's a little sensitive. :)
    ducnut Thanks this.
