I have a 2006 379 Peter. It has 1157834 miles on a C15 Acert motor. About 2.5 months ago, my jakes seem like they are only half there. They make the sound but holding the truck or slowing it down, not so much. I found that the top of my wiring harness had been rubbed through partially by the AC lines across top of motor. I had the harness repined. It seemed to work for a little bit. They went bake doing the same thing after about 75 miles. It had been awhile since the overhead was done, did it. Also replaced celinodes for the jake brakes, they also checked the voltage to them. Everything was in spec. They worked for about a week and stopped working. Now we got into compression. Found out needed rods and mains, did them. Also replaced all six injectors. Worked for about 60 miles and quit again. Found a broken wire in the harness and fixed it. I was told to check the clutch pedal switch, brake pedal switch, and speed sensor. Then I was told if it was that, they wouldn't work at all. Now the mufflers come up in conversation. Maybe plugged up. Still have factory pipes on truck. Don't know if this is the issue or not. Then a tech advised to check on turbo. There maybe some propeller blade damage, or to much side to side movement and it isn't building enough pressure to operate the jakes correctly. I'm really tired of throwing parts at it to fix the issue. Does anyone have any ideas or have had this problem before? Getting quit pricey and hope it's not just a simple fix. I know, there are no simple fixes when it comes to trucks. I would appreciate any in put someone may have.
Jake Brake Issue
Discussion in 'Peterbilt Forum' started by Recon87, Oct 10, 2013.
instead of repairing the wiring harnesses you should have replaced them. I replaced both injector and vva wiring harnesses, it did wonders . if ya went thru all the trouble to replace the injectors and didn't put new wiring harnesses on at over a million miles, you wasted your time, expecially after having had to repair several times. think about it.
the common denominator is the only thing you haven't replaced completely actually makes the thing work correctly, which is why it will do ok for 60 or 70 miles, the harnesses would be about 154.00 eachMartinFromBC and CondoCruiser Thank this. -
I agree. All the troubles you had with that harness you probably are missing hidden damage. Over a million miles running to an engine that has vibration them wires have a lot of miles themselves. Plus with known overheating there is no telling the shorts and arcing you had. Every time they work on it they move the harness.
You could remove it completely and ohm the wires out while moving it around. I bet your meter will jump.
Spend the money on a new harness and if it don't fix your problem skateboard said he would reimburse you.MartinFromBC Thanks this. -
Recon87,
I am in Engineering Product Support at Jake Brake and am contacting you after reading your post about the issues you have been having with your engine brakes. We experienced a similar issue with the same engine that we were running here in our dyno lab. I would like to give you some input even though the brake on that engine are not "JakeBrake" products. Those brakes are actually manufactured by CAT for use on that engine. That being said, I agree with the comments that say that you should replace the overhead wire harnesses. We found that over time the harnesses tend to get brittle due to repeated heat cycles and will create intermittent connections to all components under the valve cover. A CAT dealer should also be able to determine what is actually happening when you activate the brake and prevent you from "throwing parts" at this to get it fixed.
Please let me know if I can be of any help to solve your problem.
Don Shaia
Jacobs Vehicle Systems'
860-769-7806
dshaia@jakebrake.com -
Hey everyone, even tho im thinking of opening up a whole new other page, my topic has so much to do with this topic that I thought id just respond. I have a 2006 international with a C15 cat engine in it. a couple months ago it was an issue that the oil level in the pan kept rising, so I removed valve covers, I removed jake brake heads and all injectors, replaced all O-rings and reassembled. the engine ran fine and it no longer did it leaks fuel into the crankcase. however, ever since my jake breaks don't work. I have double checked all my connections and everything seems ok, I over heard a couple of the guys saying that they have needed to bleed jake heads to get them to work again because they may be somewhat air locked. so my question to you guy are the following:
1) How do I check that the jake brake solenoids are receiving power to make sure that the electrical portion of this system is working properly?
2) How do I bleed the system?
any help at all will be much appreciated -
anyone? commonnnnn
remove valve covers, remove wires to jake solenoids. get two wires one pos one neg touch the solenoid this will activate the solenoid. put a rag over the jake housing see the little plate with the dent held by the allen head screw? oil will spray out from here. do this with the engine running. if you have an issue with the electrical it will throw a check engine light while the jakes are operating.
right on, well an update is that I brought the truck into the shop, I removed valve covers and tested voltage at the solenoids and I had 12 volts so I ruled out the electrical.
after I did the injectors I guess I must have not bled it or whatever even tho I don't think that there is a way to bleed it, while troubleshooting I had my buddy in the cab reving the engine up and letting the throttle go. about 50 times he did that u could hear the jake brake slightly work, kept doing this and eventually they came back, working fine. so there musta been an airpocket in the jake heads because I did nothing to it but rev the #### out of it and they worked. -
I tried to repair the wires leading to the rear solenoid as they were damaged. It didn't even hold up to the road test. I changed the harness but that came upto about $400 (mind you this was in Fort Mac), after that all was well. Hooked up the computer and it showed 99.96% effective.
