Jake Brake Problem on C15 6nz56132
Discussion in 'Trucks [ Eighteen Wheelers ]' started by agariza, Jan 6, 2012.
  1. agariza
    agariza Bobtail Member
    14
    My Jake brakes were working good then they suddenly got week. Manifold pressure is down as well but I believe its a sensor because the truck is running good. Changed out all three sylinoids. jakes are working in low med and high however doesnt hold you back.
    Does anyone have any suggestions on what to do. The Pete is a 379, 2002 with a C15. Listed s/n of engine above.
    Thanks
  3. kklogger
    kklogger Bobtail Member
    27
    May 16, 2009
    b.c.
    if its a pacbrake might be a cracked jake head.
  4. 07-379Pete
    07-379Pete Crusty Commando-Pete
    2,549
    2,347
    Oct 3, 2008
    Campbellsville, Ky
    6nz cat didnt use the cat brake
  5. kklogger
    27
    May 16, 2009
    b.c.
    I had a truck with a 6NZ and it had a PAC brake not a CAT brake.
    Jake would be working fine then all of a sudden it goes soft.
    PAC brake head castings were to thin and they would hairline crack and bypass oil causing the jake to still work but not 100%.
    Updated ones had heavier castings,problem solved.
    Just my experience,hope it helps some.
  6. kklogger
    27
    May 16, 2009
    b.c.
    Just wondering if you fixed the jake problem?
  7. KaptainKenworth
    KaptainKenworth Bobtail Member
    33
    18
    Jan 19, 2012
    Alberta Canada
    Kinda sound like maybe a weak or broken spring, sticking contol valve, leaking solenoid or piston..also have a close look at the wiring harness for loose conections or rub spots. probably should remove the heads and inspect them .. rebuild kits are fairly inexpensive.
    Valve set is critical for performance
