"""Cummins ISX- (2003)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rogueunh, Friday at 7:58 PM.
One of our trucks has this engine in it. Symptoms past week or so have been poor mpg's, lower than usual power, a "cough" or skip when pulling a hill, and now today truck started blowing black smoke especially when shifting.
However, with the engine brake shut off, the truck seems to run normal, at least it did for the last 3 or so hours today.
I'm assuming this is an engine brake issue? Or other ideas?""""
WHAT I DID AFTER LOCAL Garage found the issue....
---unplug the square connector in the centre of the engine on the drivers side. It is the wiring harness plug for the jake brake. My wiring harness is oil soaked and as such is shorting and causing the jake to come on by itself. Once unpluged the issue went away. Give it a go and see what happens.
Jake brake stuck on even if turned on! See reference below: Cummins ISX
Discussion in 'Volvo Forum' started by Burdisco, Nov 3, 2015.
usually all isx harneses are oil soaked i have seen it create some problem what i would do is try to see if there is constant power coming to these solenoids thats shorting them out maybe a bad switch or some wire is shorting to ground, get a diagram and see what you're supposed to have where and check from there.
####. It should be even if turned off! How do you edit the title??
Ohhhh D. A. M. N. is a bad word!
Dave_in_AZ and KB3MMX Thank this. -
Haha
Does anyone have a pic of the engine brake plug.. I pulled a plug and it seemed to work for about 20 minutes and then started acting up again. Don't know if I pulled the right one.
