jake brake
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Superhauler, Dec 11, 2012.
  1. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,733
    Jan 30, 2010
    keep stroking.
    my jake started to actup today. anyone know the cat part# for a 340E rebuild kit?
  3. snowwy
    snowwy Road Train Member
    20,591
    13,309
    Jul 6, 2009
    last time i had my jakes act up. turned out to be the switch.
  4. snowman_w900
    4,418
    81,025
    Nov 25, 2010
    hey russ just if i rememebr the caterpillar part number i used for my 340E was 143-6628. that was a tune up kit. basic springs, link springs, control valves, inner and outter control valves springs and snap rings. i got the cat solenoid part numbers somewhere here.......
  5. snowman_w900
    4,418
    81,025
    Nov 25, 2010
    Russ, along with the 143-6628 kit, i forgot these incase ya wanna get deeper in it,the autolash screws were the red coded ones # 192-5502, new nuts were # 1b-4430, new soleniods were # 163-1533. each solenoid assembly come with all three o-rings. there is a special socket you can make one or buy one from pac brake for these solenoids. i bought one from pac brake along time ago for like 25.00 bucks. i totally gutted my brakes when i rebuilt them, so if ya need any more part numbers, i got'em man.
  6. underpsi
    underpsi Road Train Member
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    What serial prefix do you have with 340E's? All the MBNs i've seen with jakes are 340D's. I thought all the twin turbos from BXS and up are Cat engine brakes?
  7. snowman_w900
    4,418
    81,025
    Nov 25, 2010
    the 340E is for a later bxs. when converting a mxs accert over to single charger-70 pin 6nz style setup, having to get rid of vva/jake use a 340E# jake.
  8. Superhauler
    12,209
    100,733
    Jan 30, 2010
    keep stroking.
    the jake on 5+6 was the one. it was one of the spool vavles under the bleed plates that went bad, got her fixed. thanks everyone. the last down grade in wv on 68 was fun when it quit workin grossin 144000lbs. that's a pair of shorts that goes in the can!
  9. underpsi
    1,266
    292
    Sep 18, 2008
    Toronto, Ont
    How would a BXS have vva with a 340E jake?
  10. snowman_w900
    4,418
    81,025
    Nov 25, 2010
    DO WHAT? re read...to get RID of the vva and jake combo of a MXS, your gonna USE the 340E from a BXS( for example bxs02992) on a MXS to delete accert junk.....
  11. snowman_w900
    4,418
    81,025
    Nov 25, 2010
    hahahaha, yeah, i can understand that one.....been down many times, but never at 144000.
