jake break sticking????
Discussion in 'Peterbilt Forum' started by azbraindamage, Jan 30, 2013.
  1. azbraindamage
    azbraindamage Light Load Member
    136
    33
    May 24, 2012
    Kingman Az.
    2001 pete, we put new on/off switch on the jake, what else can we check?:biggrin_2556:
  3. saddleup
    saddleup Light Load Member
    281
    137
    Sep 30, 2011
    magnolia, ky
    sounds like solinoids sticking
    azbraindamage Thanks this.
  4. Pinner
    Pinner Medium Load Member
    410
    201
    Feb 14, 2010
    B.C.
    Broken spring
  5. azbraindamage
    136
    33
    May 24, 2012
    Kingman Az.
    Where's the solenoid located and how do I check that?
  6. azbraindamage
    136
    33
    May 24, 2012
    Kingman Az.
    The spring is on the back of the throttle seems to be ok.
  7. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    i think hes talking about one of the many springs in the jake housings under the valvecovers.
  8. azbraindamage
    136
    33
    May 24, 2012
    Kingman Az.
    that sounds like something for the shop.......
  9. Superhauler
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    if your not mechanically inclined, yep! the silinoids are also in the housings. what kind of engine is it?
  10. azbraindamage
    136
    33
    May 24, 2012
    Kingman Az.
  11. Superhauler
    12,209
    100,730
    Jan 30, 2010
    keep stroking.
    ok then one valve cover. when you say sticking. do you mean it wont turn off?
