Jake on brake cat c12, how many stages?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Brookshire36, Jan 19, 2021.
  1. Brookshire36
    Brookshire36 Bobtail Member
    18
    Apr 28, 2020
    Have a 2002 ford sterling removed had the Mercedes motor with engine brake removed and cat c12 installed with jake brakes after driving for 2 weeks I noticed that the jake brake switch only has off, medium and high, found the tag laying in floor that says 1,2,and 3 stage, is it supposed to have 3 stage or is the 1 position considered off
  3. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    No the cat c12 will have 2 switches. One sitch for on/off, the second switch will have 1,2 and 3 settings. Cat c12 has 1 jake head under each of the 3 valave covers and one solenoid powering each jake.
    You kinda answered your own question in the beginning of the post. IT is a ford sterling truck that originally had a mercedes motor in it. HAd it been a c12 from the factory, the truck would have been wired for both switches. IF i was you, i would just keep it the way it is. You have OFF, medium and high. I cant think of one time i have ever used low before.
