Jake On?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Xtreme, Jan 5, 2011.
  1. Xtreme
    Xtreme Bobtail Member
    12
    Dec 31, 2010
    Harris, MN
    2002 C15 KW T800 475 hp Just got my truck back from an over head adjustment. Had some other rear end work done as well. Seems like the Jake brake comes on a little right as you step into the pedal. Push a little farther and it goes completely away. Doesn't matter if switch is on or off or position 1 2 3. Would improper Jake adjustment do this. I am ignorant as to how a jake is adjusted and what the effects of out of adjustment would do. Thanks
  3. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    Sounds like improper adjustment. Most engines have a separate housing that bolts down over the rockers for the Jake Brake. The Jake housing will have adjustable pistons that push down on the exhaust valves. If they are too tight you will hear funny noises. If it seems wrong to you, don't hesitate to bring it back. If something is wrong the longer you wait the worse it will get.
  4. JohnP3
    JohnP3 Road Train Member
    1,594
    684
    Feb 21, 2010
    Rock Creek B.C. Canada
    If the racks on a 2 cycle Detroit are not adjusted properly they will do that.
    You have to tell us what kind of engine, and model, you have!
    But mainly if it does not sound right take it back. If the adjuster is not locked properly it can do the same thing.
  5. Xtreme
    12
    Dec 31, 2010
    Harris, MN
    Sorry about that. 2002 KW T800 with C15 Cat 475hp
  6. TIREDOLDTRUCKER
    TIREDOLDTRUCKER Bobtail Member
    17
    5
    Dec 31, 2010
    Merritt Island, Florida
    sounds like the "TECH" adjusted the jake too TIGHT. get it back FAST!
    jr-transport Thanks this.
  7. Christensen
    Christensen Light Load Member
    148
    42
    May 24, 2011
    West Palm Beach, Fl.
    I posted this question under the tread that's already here....I have seen and heard guys leave their Jake on even when shifting to get that nice growl...My question is does this damage the motor or jake at all? It can't be for any other reason, than that sound between shifts.
  8. jr-transport
    jr-transport Light Load Member
    I leave it on so I dont have to use my brakes all the time, money saver......and it sounds good too
  9. freightlinerman
    freightlinerman Road Train Member
    1,287
    536
    Mar 4, 2011
    Florida
    I read that engine manufacturers do not recommend this as it can cause engine damage, they call it "jake shifting." Unless you double clutch, I don't see how you can stop it from coming on. I find it annoying, as it cuts the throttle for a split second when you tryi to go through the gears, especially if you're speed shifting the lower gears.
  10. Christensen
    148
    42
    May 24, 2011
    Never had any issues???
  11. trucker_101
    trucker_101 Heavy Load Member
    941
    639
    Apr 23, 2010
    Alberta
    On some of the older cat engines you could have a smoke & a coffee between shifts because they were so slow in dropping rpm's. So I would leave the jake on to shift sooner.
