jerking truck while shifting
Discussion in 'Questions From New Drivers' started by hup, Jul 10, 2011.
  1. hup
    hup Medium Load Member
    592
    209
    Oct 19, 2010
    Missoula, MT
    this is about when I'm heavy, which I mostly am.
    ok, whenever I start from a stop, which I hate btw.. I have to start in like 2nd.. this is on a 10 spd E/F..
    if I start in 3rd it kinda isn't happy.. so I start in 2nd.
    when I start in 2nd, I let out clutch.. truck bounces a bit, then stops once clutch is out. I give it fuel...
    rpm is up, I shift to 3rd, no need to dbl clutch, it just slides into 3rd without a pause or anything.
    now 4th.. I raise rpm to 1400 or so, shift, but the truck kinda lurches wwhen I give it fuel. I've tried shifting higher.. but same thing really. it shifts ok, no grinding, but it lurches. can I make this smoother?
    same goes for 5th.. but as I go higher, it gets smoother of course. its mostly those low gears that cause me non-smooth shifting trouble. what am I doing wrong?
  3. THBatMan8
    THBatMan8 Road Train Member
    1,478
    469
    Feb 13, 2011
    Wherever I park
    Try double-clutching the lower gears.
  4. Elendil
    Elendil Heavy Load Member
    921
    626
    Mar 27, 2011
    Ottawa, IL
    I too drive a 10spd Eaton (KW t660). I always start out in 3rd, never lower than that, and if the load is under 40k, I will often start in 4th. Starting in 3rd you should be able to idle and pull the load (unless on an incline). Sounds like something is out of wack......
  5. tw1005tx
    tw1005tx Light Load Member
    60
    18
    Feb 24, 2011
    Broken motor mounts will make it almost impossible to not jump or jerk if its loaded
    starting out from a stop. How ever once its moving shifting with care its ok.
  6. trucker_101
    trucker_101 Heavy Load Member
    941
    639
    Apr 23, 2010
    Alberta
    is it a mac?
    123456 Thanks this.
  7. sidepocket
    sidepocket Light Load Member
    268
    88
    Mar 1, 2011
    louisa, va
    just practice...
    turn the jake off if its on...
    try doing things a little slower and smoother...
    youre learning the trans... just practice..
    Wargames Thanks this.
  8. BigJohn54
    BigJohn54 Gone, but NEVER forgotten
    1,972
    1,599
    May 13, 2011
    SW Missouri
    Is it normal to start in gears other than first? I never start a loaded truck in anything but first. To me the jerking when taking off is typical of starting in too high a gear.
  9. Onetruckpony
    Onetruckpony Medium Load Member
    544
    372
    Jun 11, 2011
    I pull light loads and start in second or third all the time if on flat ground.
    Im sure others will disagree but I find no need for lower gears to get a lighter load rolling.
    I would think if the problem were motor mounts it would do it whenever throttle/torque was applied.
    Watch your speed as well as RPM. The low side has a much tighter/more responsive spread between gears, shift slower and ease on the throttle.
    Hope this helps.
    We all get a good laugh at guys doing wheelies between gears.
    Zudo and jcroom76 Thank this.
  10. Cowmobile
    Cowmobile Medium Load Member
    609
    1,233
    May 9, 2011
    The hammer lane....
    I always start in third when loaded unless on an incline.. When empty I can start in 4th or 5th...
  11. Palazon
    Palazon Road Train Member
    1,430
    912
    Feb 5, 2009
    Tacoma, WA
    I drove at 100k lbs gross using a 13 spd (freightshaker, 4 axle truck and 4 axle trailers). Only time I dropped below 3rd was starting on a grade. Nice easy and smooth.
    PS: My light loads were 45,000 lbs:biggrin_2559:
    To OP: I can't really describe how I do it, it's kind of a "feel" thing if you get my drift. I would have the shop check the clutch adjustment and the above meantioned motor mounts.
    otherhalftw Thanks this.
