junk cat injectors!!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Superhauler, Apr 19, 2013.
  1. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    well, it happened again! scored two liners going over la veta pass on hwy 160 in Colorado. #3 injector failed and washed the cylinder and #4 went bad and washed that cylinder, but not as bad as #3. po'ed me off big time. so im sittin I alameda colo. for the week until the shop puts it back together. one of these days my luck is going to change. no more reman cat injectors for me!!
    cetanediesel Thanks this.
  3. BobbyTTour
    BobbyTTour Light Load Member
    83
    24
    Nov 30, 2010
    Spring Hill, TN
    I see international freight from The Land Down Under in your future.
  4. morehp
    morehp Medium Load Member
    699
    206
    Jun 18, 2012
    Worst thing is the shop no doubt is puttin junk reman back in!
  5. logtrucker25
    logtrucker25 Light Load Member
    70
    9
    Jul 27, 2009
    northern CA
    Yikes! I lost one today too, the plunger stuck down somehow and there was about 2 inches between the top of the injector and the rocker arm. Didn't sound good. Anyone seen that before? Good luck superhauler
  6. little cat 500
    2,046
    1,090
    Jan 17, 2010
    Abbottstown PA
    that why i don't have cat injectors in my motor any longer i went though 8 sets in two years new and remans ones as bad as the other i have ipd injectors now runs fine but does seam down on power alittle but they run smooth lol hope you have better luck soon superhauler
  7. morehp
    699
    206
    Jun 18, 2012
    What cylender did that ? One of the rear ones ?
  8. logtrucker25
    70
    9
    Jul 27, 2009
    northern CA
    No it was number one. I had just put it in a week ago but it wasn't a cat reman it was from another shop. But its the second bad one i've had from them. the other one didn't stick it was just weak. Putting in a cat reman tomorrow hopefully will have better luck. Would being stuck down let fuel go thru constantly and wash the cylinder? I drove it for about a mile after I felt it let go just to get to a good pull over spot
  9. ENR
    ENR Light Load Member
    254
    50
    Oct 8, 2009
    Ontario
    Is this just pre acert injectors ? I know a lot of acert powered trucks around my company and can't say I've heard injector problems brought up at all. Are we just getting lucky ? or are you guys dealing with older models ?
    TimsItch Thanks this.
  10. logtrucker25
    70
    9
    Jul 27, 2009
    northern CA
    not sure about superhauler, but yes mine is a 1996 3406e
  11. morehp
    699
    206
    Jun 18, 2012
    common reasons for failure
    IMPROPER FUEL FILTER OR FUEL FILTER MAINTENANCE - High efficiency 2-micron fuel filters must be consistently used. Improper fuel filters will cause excessive wear on internal injector components, shortening the life of the Unit Injectors.
    RUNNING OUT OF FUEL - Damage to the Unit Injectors will occur if they operate without a fuel supply. Fuel is needed to lubricate internal injector components. Usually the injectors for cylinders 6, 5 and 4 are damaged (in that order) when the engine is starved for fuel (this is because the fuel manifold become void of fuel over these injectors first).
    HIGH FUEL TEMPERATURE OPERATION - High fuel supply temperatures will decrease the lubrication properties of the fuel and cause damage to the injectors. If the fuel return line (to the tank) is blocked or restricted, very high fuel temperatures will be reached in the fuel manifold. Also if the fuel return line remains blocked to the tank, a build-up of air bubbles will occur in the fuel manifold. This trapped air will usually result in damaging injectors for cylinders 6, 5 and 4 (in that order) first. (depending on flow direction through the head) This is because trapped air in the fuel manifold occurs over these injectors first.
    Note: A 174-00 High Fuel Temperature Warning code is triggered when fuel temperature is above 90° C (194° F) with the engine speed above 1000 rpm.
    COOLANT OR WATER IN FUEL - Coolant or water in the fuel will cause damage to the injectors. This condition is usually due to a failed Unit Injector sleve.
    INCORRECT INJECTOR HEIGHT - An incorrect Injector Height setting (lower than spec) may cause the injector rocker to bottom out the injector plunger into the unit injector. This will decease the life of the unit injector.
    INCORRECTLY INSTALLED UNIT INJECTOR - A loose or improperly seated Unit Injector can led to injector failure. This may also cause O-ring seals to fail and combustion gases to leak into the fuel manifold (Air in Fuel). Leaking combustion gases may cause damage to injectors "downstream" (also performance complaints such as stumble or rough running under load).
