Just a quick flat bed question.
Discussion in 'Ask An Owner Operator' started by feldsforever, Jun 12, 2020.
  1. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    Are these long shiny beds aluminium? If so how much aluminium is there?
  3. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Already found what I was looking for. Not gotta find some savaged ones.
  4. Doing_flatbed_nc
    Doing_flatbed_nc Medium Load Member
    585
    846
    Mar 3, 2016
    Mine is not shiny anymore, but yes, it's aluminum mounted to steel.
    feldsforever Thanks this.
  5. feldsforever
    1,453
    1,440
    Nov 22, 2019
    I was thinking about buying salvaged alum, trailers to break down and scrap. But even the ones notvallowef back on the road are asking 4 times what I could scrap them for.
    650cat425 Thanks this.
  6. Doing_flatbed_nc
    585
    846
    Mar 3, 2016
    That's probably bc scrap yards can still use them in the yard.
    I did a contract in an Omnisource scrap yard and was amazed at the state of their yard equipment.
    Also, I never witnessed a scrapped flatbed while there. They had a yard filled with scrap van trls but never FB.
    There were guys pulling local scrap with flatbed that could never pass a dot.
    D.Tibbitt, 650cat425 and feldsforever Thank this.
  7. feldsforever
    1,453
    1,440
    Nov 22, 2019
    Lol. And where I live in the middle of nowhere. I dont even think they would be looked at
  8. Doing_flatbed_nc
    585
    846
    Mar 3, 2016
    As long as they're pulling local loads, they really don't get too much flack unless stuff is obviously dangerous.
    Once you go outside that 100 air mile range or cross state lines, you gotta be on top of everything or you'll end up paying out the nose to keep running.
    There's no way in hell I'd take a crappy trailer over a set of scales or over state lines. Too much potential for bad things to happen.
    Just look at some local dump trucks in your area. A lot of them probably run bald tires and get away with it because they haul loads 20 miles from the quarry everyday and never get dot'd by a trooper.
    feldsforever, D.Tibbitt and 650cat425 Thank this.
  9. 650cat425
    650cat425 Road Train Member
    1,548
    11,043
    Jan 26, 2020
    Pennsyltucky
    Considering the cost of a brand new aluminum flat, most guys run them til there's nothing left. In my neck of the woods, when one actually breaks at the frame by the suspension, it usually gets cut down to 35ft or so, then put back together to use locally.
  10. Doing_flatbed_nc
    585
    846
    Mar 3, 2016
    Cut down and put back together as a 35ft... that's hard core. I like that.
  11. 650cat425
    1,548
    11,043
    Jan 26, 2020
    Pennsyltucky
    It's pretty easy with a ritenouer because they're bolted together. The 2000 my mrs was pulling broke just behind the front spread. I sold it to a friend of mine and he had it down to 34 ft and on the road in 9 days.
    feldsforever and D.Tibbitt Thank this.
