I am looking at buying a Cascadia Evo in the near future and wanted to know is it pretty easy for the top bunk to be removed? I assume you unscrew a few visible bolts and it comes off? I know it folds up out of the way but I have a reason of why I want to remove it without going off topic.
Just want to confirm something about removing top bunk
Discussion in 'Ask An Owner Operator' started by TruckRunner, May 24, 2018.
so you dont hit your head?
TruckRunner Thanks this. -
You don't think you can get away without telling us why you want it removed do You? Truckers are some nosey people sometimes.Smut, jammer910Z, TruckRunner and 1 other person Thank this.
Wanna build my own shelving higher up near the ceiling for more headroom. I just want to know if it just unbolts from the wall
And here's the part where the guy with the nose problem says, uh gee I don't know.
It should. I doubt they installed it before the body was set on the chassis.
Or, perhaps they did.
Just looking around my cab... without a large sleeper door that sucker will be hard pressed to get out.TruckRunner Thanks this. -
That's a good point. I can always cut the bunker in half with my jigsaw or reciprocating saw if necessary. A jigsaw with metal cutting blade can do amazing things.
jammer910Z Thanks this. -
Likely easier and less mess to unbolt the passanger seat, remove it and slide the bunk out that eay.
Justrucking2 Thanks this. -
So in our Volvo, we had to take out the side cabinets in order to get the bunk out in one piece. No matter which way we angled it, there was always something in the way to prevent it from coming out. The top bunks are smaller in the freightliners, so you might have better luck, but I'd think you have to take out at least one side.
use it for the base of your shelfs ...... always saws all it in half ... be an adventure getting it out in one piece. . hard enough changing mattress and that bends
