k40
Discussion in 'CB Radio Forum' started by CAZ, Mar 15, 2008.
  1. CAZ
    CAZ Light Load Member
    86
    Oct 24, 2007
    escanaba michigan
    Anybody out there running a k40 on there mirrior mounts and if you do how do you like it ? I have been running one on the 26 ft van body I ran and it seem to work good. Just would like someone elses opioin.
    Also How good is the built in mounts and cable on the freightliner.
  3. lyion
    lyion Light Load Member
    96
    5
    Feb 2, 2008
    TOANO VIRGINIA
    the factory cable arent any good there usely cheap of the line alwayss go with good cable and the shourter the beter .long cables eat up oms they work but shourter ones lose less oms .
  4. Carolina Thunder
    Carolina Thunder Medium Load Member
    584
    179
    Jan 28, 2007
    Coeburn V.A.
    K40 anything is junk and you will be better off to spend a little extra and get a Wilson. I have tried them ( K40 ) and i know, they are a wast of money!
  5. kd5drx
    kd5drx <strong>Master of Electronic Communications</stron
    485
    102
    Nov 28, 2006
    Some where USA
    Any center load antenna is a compromise but for what its worth the K 40 is as good as the rest. The coax in a factory rig no matter what brand is the cheapest they7 can get by with and not measured just thrown in so allways go with after market coax and the more shielding and the bigger the size the better. If you can get away with LMR400 is the best but its a little bit of an over kill on a mobile install. Stay with the RG8 or RG8X and the 9 or 18th length for the wave length you are working with try to stay in the quarter or half wave length and you will get a better performing system.
  6. CAZ
    86
    Oct 24, 2007
    escanaba michigan
    I guess I should clairafie I'm talking about the k40 steal whip the kind you normaly have on a mag mount. Not the fiberglass
  7. Truckerjo
    Truckerjo Road Train Member
    2,314
    341
    Sep 5, 2006
    Indiana
    K40 will perform just as well as a wilson 2000 or 5000.. I have tried them all.. the only real issue with that type of antenna is the plastic around the coil, during the winter the plastic gets a little brittle, the whipping action of the rod "can" (key word there people) cause stress cracks at the top, this will allow moisture in and corrosion will start, this will cause your SWR to swing back and forth, antenna basically junk after that happens..
    Antennas like Monkey made and Striker don't have this issue, but still always a good ideal to keep them clean with compounds such as never dual ext.. An issue they do have is sombody wanting it more then you and stealing them..
    Fiberglass Antenna
    I would say a simple Frances is the best I ever have tested.. A little hard getting the SWR set but well worth it...
