Kenan Transport pre hire physical?
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by mattfield80, Jan 18, 2013.
  1. mattfield80
    mattfield80 Light Load Member
    216
    19
    Jun 29, 2012
    Kernersville NC
    im scheduled to start with kenan monday with the dot physical and drug test etc...then safety class the next morning, then training with another driver for a couple weeks...can anyone tell me if kenan uses a work well physical as well...you know the thing where you have to lift the weights, push, pull for certain weights, and do they do a step test, (and if so, how long?) please give me some details...thanks alot
  3. WideSkyND
    WideSkyND Light Load Member
    211
    47
    Apr 16, 2012
    Each company has a certain min weight lifting, pushing and pulling criteria, so what happens typically in these fit for duty tests is a sampling of all of that, but at a heightened level.Self explanatory, you will be able to meet the companies requirements on a daily basis. For instance on the lifting, if the max you'd expect to lift is 50lbs, they'll push that to 75-80 at the test site, and you will have to eventually start the lift from ground level, weights are piled in a milk crate or wood box with handles, normally 25lbs is 1st added, then progressively moved to the max. The hardest part is getting that crate to shoulder level as you stack the crate to this high shelf after all the weights are added. And you'll do the lifts repeatedly, 15 in a row then rest. 2-3 cycles. Lest I forget, all this in addition to a heart monitor band placed around the chest and one on wrist. Pushing requires approx 400-500lbs across floor, long hallway, and then pull, this is a progressive weight added routine. Then the crate carry, this was hard at the end, out of breath and I think that was 100lbs, you carry the box to a distant point, set it on table,, then grab up and return. In between, also you get the stairwell climb, up two, down and back up. You might be required to use this strength resistance machine, it'll test your core body strength, quick test though, this part is is easy in comparison.
  4. mattfield80
    216
    19
    Jun 29, 2012
    Kernersville NC
    well i just called kenans headquarters and spoke to a lady in safety. I asked her if there is an additional pre work screen along with the regular dot physical and drug screen. She told me they used to do it and practically everybody passed so they dont do it anymore. Just the regular ole drug test and physical. She said they were not getting any real return on the prework screen...so i guess thats a good thing lol
  5. WideSkyND
    211
    47
    Apr 16, 2012
  6. mattfield80
    216
    19
    Jun 29, 2012
    Kernersville NC
    righto? please elaborate lol
  7. WideSkyND
    211
    47
    Apr 16, 2012
    ok, righto and all that, ok? surprised they'd say it was dropped though,don't worry too much as most of us stress the new hire criteria screening
  8. mattfield80
    216
    19
    Jun 29, 2012
    Kernersville NC
    i guess well see in the morning. she said id be doing just the regular dot physical and drug screen....i was surprised as well....i guess cost cutting came into play? who knows? im not the strongest guy in the world though....and anything over a 1 minute step test and we may have a problem...lets just say i can get in better shape than where im at now...im also surprised there hiring me with NO tanker experience....am i lucky? :biggrin_25524:
  9. WideSkyND
    211
    47
    Apr 16, 2012
    now that you did ask? this kinda info shouldn't bust anyones bubble either as companies in general cut wages to the bone last 4yrs......so here we go...Kenan,...near bottom of barrel pay, waste management like philosophy of having the whole fuels market at any price, your wages will take yrs to reflect actual exp level and production, forced dispatch,....wonder now why they are dipping into the rookie pool? that crazy background check this company brags about does little for what you'd expect to get back.....an associate out by Olympia told me kenan just bought another regional hauler, he's getting out as they are looking to do a retake on salaries(reduction in wages)
    positive side? tanker and fuel exp, qualifying through kenan puts you in an enviable position after about a yr I'd say to move to Pilot, Maxxum and others. Chemicals too, though I tend to stay away as anhydrous ammonia and such is to much on the plate for my tastes(been there,done that)
  10. mattfield80
    216
    19
    Jun 29, 2012
    Kernersville NC
    ill be honest and say im happy to get my foot in the door and get some tanker experience. i wont be doing fuel however, but butane. Offloading from a railyard a bit down south then delivering to area fuel yards....itll be more than ive ever made, even if by industry standards its low. (as you put lol) and home every which is always good. the terminal manager seems like a good guy. my interview was in early december and i just got the call to come in a few days ago. I called him like 6 times though lol, and i guess he liked the persistance...what background check they brag about? i havent heard about that....
  11. WideSkyND
    211
    47
    Apr 16, 2012
    Butane? Awesome, I 'd do that or propane, propane preferred. ...early dec app? so that means a 4-5wk process, about what heard from others....wonder why, since they have same access as others, and over where you are? thought that region had lotsa tanker wanna be drivers...so it is tightening up as predicted...looking for an upgrade myself in pay by mid summer if things really go crazy...not that I'm complaining, which for me is not normal, course said previous wages have been held artificially low since the last of the bush yrs..if the economy grows by more than 3% through June, expecting hades to break loose transpo wise....retention pay, all of it...yesssssss
