Kenworth 07 T600 No turn signals????
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Chickentrucker20, Nov 8, 2018.
  1. Chickentrucker20
    Chickentrucker20 Bobtail Member
    19
    Jan 25, 2018
    Kenworth 07 T600
    I was in a rush Sunday and crossed red and black wires on heard bumper blinkers, now no blinkers anywhere on truck or trailer, several lights on dash out and some lights like parking brake light and fridge light are always on when they shouldn’t be. Also lost low beam right side led headlight about 2 days later, same light works on high beam. Been skirting around western Nebraska this week without blinkers, gonna tackle it Saturday. Any help greatly appreciated.
  3. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,334
    Feb 21, 2015
    Bement, IL
    Have the same truck. Gonna follow this as it could easily happen to anyone.
  4. lester
    2,930
    7,925
    Jan 2, 2012
    NW, Iowa
    Did you check your fuses? Blown fuse or tripped breaker can do some funky things
  5. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
    And this is why the DOT has a job.
    Your Krap is broken. Stop and fix it before you move one more mile
    The broken damaged Krap I see truckin around 94-80 Blows me away
    Diesel Dave and lester Thank this.
  6. Chickentrucker20
    19
    Jan 25, 2018
    Checked fuses, flashers, bought a blinker switch. Hazards work, just no blinkers.
  7. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Did it fry the switch somehow?
  8. Chickentrucker20
    19
    Jan 25, 2018
    I hope not, I know it could be 100 diffent things, not really any point in asking for help.
  9. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    I can help you on the LED headlight. We ran accross this accidentally. It was caused by getting the connector wet and energizing high beam power to low beam power at the same time. Gets them every time!! We’ve started coating the connectors (not the terminals) in dielectric grease to keep moisture out.
    As for your blinkers, if your hazards are working then the flasher is probably fine. Is the blinker on the bumper a repair or is the bumper an added upgrade? Although there’s still a chance this is an unrelated issue that just happened at the same time, more than likely it’s coming from the area that was worked on. Crossing the turn and clearance circuits don’t normally cause a short or failed component. Usually just back feeding issues that cause things to work when they are not supposed to!!
    First thing I would try is to disconnect any added or repaired lights and/or harness’ that may have been modified and see if the rest of the lights starts working again ( may have to wait a few minutes for a breaker to reset). If that doesn’t get you close then get out the test light and a creeper and set your beer down by your bible and start looking at schematics!!!!
  10. Chickentrucker20
    19
    Jan 25, 2018
  11. Chickentrucker20
    19
    Jan 25, 2018
    Thank you for your time and info. Bumper was added after I hit a deer, KW did all of that work maybe 2 years ago. The marker light/blinker on the bumper was going out and that’s when I started messing with it, hopefully it is localized since everything beyond that still had power. So on the headlights just unplug the connectors and make sure clean and dry? I’m pretty simple when it comes to working on my truck.
