kenworth 2007 13 speed won't shift from low to high
Discussion in 'Kenworth Forum' started by mert, Jun 8, 2014.
  1. mert
    mert Light Load Member
    90
    10
    Jul 13, 2013
    It shifts fine on the low 4 gears,and reverse,it goes into here in 5th-8th but won't engage,i can hear the air hissing when i flip the flipper,but not the metalic click,i do hear the click when i move th red button
  3. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    Leaking air line. Do you hear hissing right at the shifter or further down?
  4. mert
    90
    10
    Jul 13, 2013
    Right at the shifter,i pour soap and water on the hose and fityings down below,I changed that box that does the shifting, nothing
  5. milskired
    milskired Road Train Member
    3,829
    1,401
    Jul 20, 2007
    Plainfield, IL
    Do you see bubbles from the soap and water? Did you replace your air lines too?
  6. mert
    90
    10
    Jul 13, 2013
    No, no bubbles,no i didn't replace the airlines
  7. milskired
    3,829
    1,401
    Jul 20, 2007
    Plainfield, IL
    Is it louder in or outside the truck? I would just start taking things apart and looking for loose fittings or cracked lines. Probably going to be a big headache for a 10 dollar part!
  8. mert
    90
    10
    Jul 13, 2013
    Is no air leak,I looked. How big the air leak has to be to affect the shifting?? I took the knob apart,I looked under the truck,no bubbles
  9. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    hissing means an air leak, something may be blocking the air in the new splitter box you installed, or the plunger is stuck in it. beat it with a hammer, or I should say tap it
  10. mert
    90
    10
    Jul 13, 2013
    So when I move the flipper shouldn't hear the air noise? ??
  11. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    If you have some allen wrenches you can take apart the top of the shifter handle. Drain the air down to zero if you can and be very careful when taking it apart, there is a small ball bearing in there, also a chuck(oval piece with one side has a ridge in it) - also 2 very small gaskets. If you have air pressure it will blow these things all over the place and you can't shift without them. I just had this problem last week. It is pretty self explanatory how it all goes back together. But not a very difficult thing to do. Hope you have your tools.
