kenworth 2007 13 speed won't shift from low to high
Discussion in 'Kenworth Forum' started by mert, Jun 8, 2014.
  1. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,116
    May 19, 2011
    Did it hiss like mad when you split the gears? That spring is what puts pressure on the rubber gaskets to seal them when you split gears.
  3. mert
    mert Light Load Member
    90
    10
    Jul 13, 2013
    Yea sir that box
  4. mert
    90
    10
    Jul 13, 2013
    Is the normal hissing when I move it up and down,short ,just like before when was working
  5. Oscar the KW
    12,246
    28,116
    May 19, 2011
    When you took it off was there air pressure there?
  6. mert
    90
    10
    Jul 13, 2013
    Oh yeah,Lotta of air came out when I removed the red and green hose
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,768
    Mar 5, 2012
    Ontario Canada
    Well the splitter still isn't perfect the way it should be. But there is a small air leak which quickly goes away - on it's own - it isn't instant - but it functions.
  8. Oscar the KW
    12,246
    28,116
    May 19, 2011
    I think that you have something inside the transmission that is stuck or broken, I believe that it will be inside the back box.
  9. mert
    90
    10
    Jul 13, 2013
    I hope not,thank you so much guys for all your help and time, I tried everything, I'm stuck in pecos for 2 days now, Dumbo what to do: )
  10. passingthru69
    Sounds like maybe the inner shift crapped out on him. I know a company trk. I drove years ago went out and I was stuck in low. It's in the back box. Right now I can not think of the proper name of it right now.
  11. KWmech
    KWmech Light Load Member
    141
    40
    Jun 16, 2012
    Sounds like a synchronizer problem in the back box, does it grind at all while range shifting?
