Kenworth 2012 eaton auto transmission, hitting breaks by itself
Discussion in 'Experienced Truckers' Advice' started by Gurjap, Sep 18, 2022.
  1. Gurjap
    Gurjap Light Load Member
    57
    11
    Mar 18, 2020
    Hello friends,
    I have a cummins with an auto transmission (eaton).
    when I drive on a slippery surface, the truck hits the breaks by it self and it makes a sneezing like noise. Which sounds like an air valve is being released. My mechanic suggested that I plug out my traction control so that it can never be used and I won’t have this problem again.
    If I listen to him and do that will it cause any problems to my transmission? Is doing this dangerous? Please let me know.
  3. circle h
    circle h Light Load Member
    240
    375
    Oct 22, 2020
    Isn't there a switch that says TC with a tire on it? If there is that controls the traction control. Turn it off and give see if that helps.
    Oxbow and Magoo1968 Thank this.
  4. kylefitzy
    kylefitzy Road Train Member
    4,724
    19,660
    Aug 12, 2007
    Kansas city,Mo
    What’s the issue? That sounds like traction control is working as it should. (Not that it works very well in my opinion) traction control applies brakes to the wheel or wheels that are spinning “forcing” the power to go to the wheel with traction.
    Oxbow Thanks this.
